discojon Posted September 10, 2014 Share Posted September 10, 2014 I'm looking for volunteers to send me their unneeded / unwanted engine / suspension brackets. I will media blast them, and powder coat them and then offer them again for exchange to others wanting the parts. Initial Donors will get Recognition in the next post for Paying it Forward! The way I envision it working is, you contact me with what bracket you want to exchange for a coated one, I'll verify that I have it and if I do I'll send it to you no charge! This will only work if you send me back your old bracket so I can continue the routine of cleaning and coating. The only cost you will incur is shipping both ways and any form of donation you may want to make (not mandatory but encouraged). All brackets will be flat black powdercoat. On my car I have already coated the TMIC support arm, battery tie down and bolts, and engine cover mount (over alternator). There are many, many uncoated brackets on the LGT engine bay and as long as it's not costing me anything, i'll donate my time and equipment. If you have a need other than bracketry, pm me. Turn Around: The turnaround time should be quick as long as I am getting returns from folks. I have a life and a full time job but I'd say no more that a couple days a most. I don't think I need vendor status since I'm not selling anything, only offering a service, but mods let me know if I do. To get started I'd appreciate if someone would donate (I'll cover shipping) the following: TMIC support armFront Engine Cover SupportPulleys (various)Belt Tensioner bracketry for AC beltBattery hold down and boltsTurbo heat shieldsTurbo BracketsExhaust BracketsRadiator Support BracketsAirbox clipsCaliper bracketsBasically any bracket that you have laying around. Link to comment Share on other sites More sharing options...
discojon Posted September 10, 2014 Author Share Posted September 10, 2014 Initial Donors That Made this Possible: Max Capacity Link to comment Share on other sites More sharing options...
discojon Posted September 10, 2014 Author Share Posted September 10, 2014 Photos: Battery hold down http://tapatalk.imageshack.com/v2/14/09/12/d78e72e97e22d336f96fcc9c07f9042f.jpg TMIC support arm http://tapatalk.imageshack.com/v2/14/09/12/69bc2b19e161866927ad8c3f05819d76.jpg Engine cover bracket http://tapatalk.imageshack.com/v2/14/09/12/bc7c2500b6295b71388e7c4088ff24d2.jpg The process: Front caliper bracket as received from Max Capacity http://tapatalk.imageshack.com/v2/14/09/19/23a79afe7aa77c1b8e2fce43cbf60954.jpg Going in vibrator http://tapatalk.imageshack.com/v2/14/09/19/3e0327cc4c71ef0d1a417594a92c0e4d.jpg Out of vibrator and mostly degreased http://tapatalk.imageshack.com/v2/14/09/19/4eab4d557407cda71ee6a79b5ef9e59b.jpg Left post blasting, right only out of tumbler http://tapatalk.imageshack.com/v2/14/09/19/7e0d1cc6f0676bcd2f2c20047561fa64.jpg Coated and cooling http://tapatalk.imageshack.com/v2/14/09/19/a4719b5d1402d6d357be270f49565c22.jpg http://tapatalk.imageshack.com/v2/14/09/19/ee7f85a31cb3a6656f7e27aa3a6452b8.jpg Link to comment Share on other sites More sharing options...
snow05gtRI Posted September 12, 2014 Share Posted September 12, 2014 wow. awesome service you're providing here. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2014 Share Posted September 12, 2014 I just replaced 3 front caliper brackets. I got the frozen pins out of two of them the third has the pin still in it. I throw them in my recycle bin, do you want them ? If you could clean up the rusty holes, the pins came out with not much issue. Do you want them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
discojon Posted September 12, 2014 Author Share Posted September 12, 2014 I can clean the rust off and blast them so sure. I'll pm you mailing info Link to comment Share on other sites More sharing options...
discojon Posted September 16, 2014 Author Share Posted September 16, 2014 Bump. Still looking for donors and recipients Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 16, 2014 Moderators Share Posted September 16, 2014 I'll take a look around for stuff as soon as life slows down a bit. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2014 Share Posted September 16, 2014 Bump. Still looking for donors and recipients will have a tracking for you in a couple hours. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
discojon Posted September 16, 2014 Author Share Posted September 16, 2014 Thanks BMB and Max. I'll get the brackets cleaned up and coated and get some photos up. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 16, 2014 Share Posted September 16, 2014 I have the transmission cross-member. Link to comment Share on other sites More sharing options...
discojon Posted September 16, 2014 Author Share Posted September 16, 2014 I have the transmission cross-member. Not sure if the x-member will fit in my current oven. Big oven isn't finished yet. Let's keep the scope to bracketry and small parts for now. Thanks though. Link to comment Share on other sites More sharing options...
discojon Posted September 19, 2014 Author Share Posted September 19, 2014 Bump. Added new photos. New compressor is going in today. Will greatly expedite the process http://tapatalk.imageshack.com/v2/14/09/19/03427c6dd626ae806f8de123c6f4459f.jpg Link to comment Share on other sites More sharing options...
discojon Posted September 20, 2014 Author Share Posted September 20, 2014 I think this says it all. These are going on my car next brake job unless someone takes them first... http://tapatalk.imageshack.com/v2/14/09/20/c8eb5ab39fd1181b2e8b65fa99b1fa89.jpghttp://tapatalk.imageshack.com/v2/14/09/20/02bf1a8cdf2349110884cb83f273a2a1.jpghttp://tapatalk.imageshack.com/v2/14/09/20/22f2de41438eab4bb5bd9be06d906b33.jpg Link to comment Share on other sites More sharing options...
JJr Posted September 20, 2014 Share Posted September 20, 2014 Wow, great work! Baked in the white oven? Link to comment Share on other sites More sharing options...
discojon Posted September 20, 2014 Author Share Posted September 20, 2014 Yep. Big one isn't done yet. http://tapatalk.imageshack.com/v2/14/09/20/3b1f2e080b7a5fa984bed8b61ce1ea86.jpg Link to comment Share on other sites More sharing options...
discojon Posted September 23, 2014 Author Share Posted September 23, 2014 The front Caliper Brackets are spoken for. Will have them restocked in a few weeks. Have a set of rear calipers and brackets coming in to do for a customer. Link to comment Share on other sites More sharing options...
discojon Posted September 27, 2014 Author Share Posted September 27, 2014 Rear brackets and calipers I did for a member. http://tapatalk.imageshack.com/v2/14/09/27/d045a430d5949fbe596c245452b3411d.jpghttp://tapatalk.imageshack.com/v2/14/09/27/041270d70a7df6aafd16818849c2e958.jpghttp://tapatalk.imageshack.com/v2/14/09/27/b2522f7f958d9bfdb3545ac8d3d1b883.jpghttp://tapatalk.imageshack.com/v2/14/09/27/5b78a616f5d2184339f66091c30a1383.jpghttp://tapatalk.imageshack.com/v2/14/09/27/417cafbe046020c652f68347b9363bbf.jpghttp://tapatalk.imageshack.com/v2/14/09/27/8f12e8d369224c8f88595c7b9fd3a38f.jpghttp://tapatalk.imageshack.com/v2/14/09/27/d99f97d46ac839db5d3cbb41cb9427c7.jpghttp://tapatalk.imageshack.com/v2/14/09/27/f991625bd35b640e366364869ea762c4.jpghttp://tapatalk.imageshack.com/v2/14/09/27/abc46e322f93fe6b3d58d3a0c736cc5c.jpg Link to comment Share on other sites More sharing options...
Redslaya Posted September 28, 2014 Share Posted September 28, 2014 Can you only do black powder coating at the moment? Link to comment Share on other sites More sharing options...
discojon Posted September 28, 2014 Author Share Posted September 28, 2014 Black is what is included in the exchange program. I'm not a vendor so I can't sell services on here. Feel free to pm me any questions you have. Link to comment Share on other sites More sharing options...
discojon Posted October 18, 2014 Author Share Posted October 18, 2014 Anybody else interested? Link to comment Share on other sites More sharing options...
snm95ls Posted October 18, 2014 Share Posted October 18, 2014 I'd love to have some things done, but I don't have cores and I can't really have downtime since I only have one vehicle these days. Link to comment Share on other sites More sharing options...
08Legacy-GT Posted October 20, 2014 Share Posted October 20, 2014 and you do this out of the kind of your heart? 2017 Subaru STI 2008 Subaru Legacy 2.5i limited Link to comment Share on other sites More sharing options...
discojon Posted October 20, 2014 Author Share Posted October 20, 2014 and you do this out of the kind of your heart? Not costing me anything but my time and a few cents worth of power and powder. Pretty surprised there hasn't been more uptake. Oh well. Link to comment Share on other sites More sharing options...
eljefe1981 Posted October 25, 2014 Share Posted October 25, 2014 I would love to send you some parts but I can't have any downtime. Link to comment Share on other sites More sharing options...
