GTPpilot Posted June 21, 2013 Share Posted June 21, 2013 Ok, seems crazy but I have been chasing a noise all week that started after I completed the timing belt service last weekend. When car is warm I hear a weird noise. Kind of a light metallic rubbing noise. I thought at first it was an idler or the alternator etc. etc. I was just listening to the car as it warmed up and the noise appears very suddenly. I took the a/c and alt/ps belts off just to see what happened. No change. If I let the car cool down the noise stops but then suddenly reappears. This only happens at IDLE. If I even lightly touch the throttle the noise disappears. Is it possible the Thermostat is making the noise as soon as it opens ? And why ? I put a brand new OEM thermostat in when changing waterpump. Used gates kit but with OEM thermostat and OEM waterpump gasket. As I sit here looking at the original waterpump the only thing I can think if is that the little bypass valve thing is resonating somehow. The noise doesn't really bother me...just want to make sure it's not something that could cause a problem with the timing belt. Link to comment Share on other sites More sharing options...
GTPpilot Posted June 23, 2013 Author Share Posted June 23, 2013 Well, whatever it is, I'm beginning to think it was probably always there. I just never heard it because it was masked by the squeaky a/c idler. Just another thing to monitor and drive myself crazy over. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 26, 2013 Share Posted June 26, 2013 That's highly likely. It could also be air in the system? When the T-stat opens up you are hearing air bubbles circulating through the rad? Probably a stretch but worth an investigation. -mike Link to comment Share on other sites More sharing options...
GTPpilot Posted June 26, 2013 Author Share Posted June 26, 2013 Thanks Mike, I will definitely see if I can force some more air out of the system. It's weird because if I blip the throttle the noise goes away. Once it settles back at idle it then takes a couple of seconds for the noise to come back. Freaks me out because it sounds so much like a rotating/rubbing kind of noise. If all else fails I'll open the covers back up and see if anything looks / feels funky. Link to comment Share on other sites More sharing options...
