4snowandrally Posted February 18, 2009 Share Posted February 18, 2009 Ok I am stuck. I have searched for this but nothing is seams to work. I am having no troubles with logging my car or using learning view, it is just reading my rom that is not working. I have ecuflash version 1.41.2483 and definitions 0.8.2b. Well this is what it says on my ecuflash. What is going on is that the read your ecu button is on. When I push the button a little screen pops up were it shows a cancel and a read button. Only the cancel button is able to be clicked on. What is going on. Here is what my ecuflash main screen says. [08:19:10.080] EcuFlash Version 1.41.2483 [08:19:10.080] OS Version Windows XP [08:19:10.080] Qt Version 4.4.0 [08:19:10.090] 26 memory models read. [08:19:10.090] scanning for metadata models in C:/Documents and Settings/Dell/Desktop/ECUFlash/ECUFLASH STANDARD units SUBARU ECU definitions 0.8.2b 10-03-08/subaru/Legacy GT [08:19:10.110] 29 ROM metadata models scanned. [08:19:10.110] checksum module "subarudbw" loaded. [08:19:10.110] checksum module "mitsucan" loaded. [08:19:10.110] flashing tool "wrx02" loaded. [08:19:10.110] flashing tool "wrx04" loaded. [08:19:10.110] flashing tool "sti04" loaded. [08:19:10.110] flashing tool "sti05" loaded. [08:19:10.110] flashing tool "mitsukernel" loaded. [08:19:10.110] flashing tool "mitsukernelocp" loaded. [08:19:10.110] flashing tool "mitsubootloader" loaded. [08:19:10.110] flashing tool "shbootmode" loaded. [08:19:10.120] flashing tool "shaudmode" loaded. [08:19:10.120] flashing tool "subarucan" loaded. [08:19:10.120] flashing tool "mitsucan" loaded Link to comment Share on other sites More sharing options...
merchgod Posted February 18, 2009 Share Posted February 18, 2009 Your problem is that you changed the metadata directory to point to the Subaru defs only that you downloaded. The metadata directory also contains the read templates which the Subaru folder does not have. You need to follow the directions that are posted with the defs -> delete the Subaru folder in x:\openecu\ecuflash\rommetadata, unzip the current defs in the same directory. Then set your metadata directory back to x:\openecu\ecuflash\rommetadata. NOT ...\rommetadata\subaru either. Link to comment Share on other sites More sharing options...
4snowandrally Posted February 18, 2009 Author Share Posted February 18, 2009 OK thanks I will give that a try thank Merchgod. Link to comment Share on other sites More sharing options...
4snowandrally Posted February 18, 2009 Author Share Posted February 18, 2009 Merchgod everything is working correctly thank you for the quick responce today. Link to comment Share on other sites More sharing options...
