seabee70 Posted July 11, 2012 Share Posted July 11, 2012 It's been a while since I posted,but my '05 legacy gt needs help. I had the dealer install thicker sway bars bck in '07,that I bought online but I forgot who I bought them from. The bushings,according to the service tech,are worn & causing a clunking sound as I drive over bumps & manholes that are not level. They replaced the front shocks & end links,which did not cure the problem,so they say to replace the bushings on the sway bars. Please reply with a source where I might buy new bushings. Thanks for your help. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 11, 2012 Share Posted July 11, 2012 Lots of them on ebay. Whiteline or Rallitek make some great bushings. Link to comment Share on other sites More sharing options...
Socalturbo Posted July 11, 2012 Share Posted July 11, 2012 are you sure its not the LCA bushings? Link to comment Share on other sites More sharing options...
NWSPECB Posted July 11, 2012 Share Posted July 11, 2012 ^Check these before you start throwing parts at it. Vendor to Member Sales Vendor Specific Forums More specifically if you would prefer to support vendors who actually support the community look at Infamous Performance or AZP Installs. Welcome to the forum. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted July 11, 2012 Share Posted July 11, 2012 If your RSB is 22mm, I can send you a set for $15 shipped, PM if interested. Also, if you post photos, it's possible someone could ID the bars for you. And welcome to the forum. Tits mcgee Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 12, 2012 Share Posted July 12, 2012 delta, my RSB is 22mm, what kind of bushings do you have? Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted July 12, 2012 Share Posted July 12, 2012 I've got a set of beefy Progress bushings with some pretty trick adjustable brackets. I had them on for about 2 weeks before I replaced the 22mm Progress with a 20mm Whiteline. They're essentially new. The catch is, the brackets won't fit any other kind of bushing, so when you replace them, don't toss the OEM bracket (like I did). If you want them, shoot me a PM with your PayPal info. I'd still be using them if I had a 22mm bar. Tits mcgee Link to comment Share on other sites More sharing options...
seabee70 Posted July 12, 2012 Author Share Posted July 12, 2012 My FSB is 1" thick,or 25 mm & suspension connection is the only place ,so far,that has that size. Has anyone dealt w/them ? Thanks for all the input. Link to comment Share on other sites More sharing options...
ethanxk15 Posted July 13, 2012 Share Posted July 13, 2012 Just google it Link to comment Share on other sites More sharing options...
PeterJMC Posted July 26, 2012 Share Posted July 26, 2012 Welcome to the site! Link to comment Share on other sites More sharing options...
xero287 Posted July 26, 2012 Share Posted July 26, 2012 My FSB is 1" thick,or 25 mm & suspension connection is the only place ,so far,that has that size. Has anyone dealt w/them ? Thanks for all the input. Wait, so you have Perrin bars? Is the bar red or black? If the bar is red, then it's Perrin, if it's black then it's a Tribeca Bar. Either way, you can contact Perrin or Energy Suspension or even Subaru to get the bushings. Link to comment Share on other sites More sharing options...
seabee70 Posted July 27, 2012 Author Share Posted July 27, 2012 I'm guessing Tribeca is one of their models if memory serves me. Perrin is new to me but I'll google it. Energy supension has 1" bushings but they may not fit in the clamps,if the dimension I got from Amanda is correct. Thanks for the help. Link to comment Share on other sites More sharing options...
