ABS Light on. Will AWD be affected?
96 Legacy L sedan with rear disc brakes. 4EAT transmission. I wasn't sure if the AWD operation would be compromised if my ABS light is on. I was thinking it wouldn't since ABS was an option on the "L" submodel.
RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles
A bad ABS sensor signal has been detected by the "touching the wires" method of reading the ABS flashes to get codes.
However, Dosen't the same AWD system get used on non-ABS equipped cars. I'm hoping the two systems aren't reliant on one another.
Found the answer to my question. There are 2 speed sensors supplying the TCU. Vehicle speed sensor #1 mounts to the transmission and monitors the rear axle. Vehicle speed sensor #2 is built into the combination meter. The ABS wheel sensors are not instrumental in the AWD function.
