Invidia divorced DP
Are we still grinding down the plate or just run them as they come ?
I just bought a used one. There are on marks where the WG was hitting it, so I'm guessing it must have been working fine.
Engine Build - Click Here
Max does yours have the donut gasket on the rear of the pipe? I also bought a used one must be a first gen and wondering about the flapper touching also.
No, just a 3" hole with a 2 bolt flange. I have a grimmspeed 2X thick gasket for it just like the Invidia DP on my wagon. This DP also came with a grimmspeed adaptor with a donut, but I'd rather not use that.
I had to cut about 1/2" of plate out of the DP to get it to bolt up.
I had to plug in the AP twice to get it to load the stage 2 map.
Yea, nothing is ever easy.
Runs good, it's a little louder, but still no bad for stock mid pipe and no mufflers.
Hey Max, do you have muffler deletes or did you just unbolt the mufflers. I took off my mufflers to see if i wanted a loud exhaust. I took a impromptu 500 mile road trip without the mufflers. They pretty much destroyed by fender liners. They melted them pretty badly and you can see my harness in the rear.
I have deletes. I had them made for the wagon years back. Had to have them shortened for the Spec B. I bought nice tips for them.
http://i185.photobucket.com/albums/x40/92Si/DSCN5306_zps8cdc8f8a.jpg
Here they are on the wagon
http://i185.photobucket.com/albums/x40/92Si/DSCN4158.jpg
