The build begins
I put in my request a couple of weeks ago, but no one listened, so I had to do the yard work first. Now that it's done on the the 05 LGT engine build.
Here are some of the internals.
http://i433.photobucket.com/albums/qq54/wurkenman/LGT/P1010282.jpg
The crank. What is the clearance on the rods to the crank. These feel kind of loose.
http://i433.photobucket.com/albums/qq54/wurkenman/LGT/P1010285.jpg
If you woke up today, you have another chance to do it right.
Checked the rod clearance and it is good at .0015. Now just waiting for the right main bearings. Seems that I bought an under size set. Not only am I getting old, apparently I can't frikin read either.:rolleyes:
Got the right bearings. Block halves together.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-01134611.jpg
Almost too pretty to hide in an engine block.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-01134659.jpg
Aren't you supposed to put the pistons on the rods before the case halves go together? This ain't no VW...
Not possible. At least I can't figure it out.
Correct that why there are those ports in the side of the block.
That's one of the pieces that make these engine rebuilds labor intensive and why my buddy told me to get a new oem short block instead of paying his shop to rebuild my old short block.
If I want a 400whp+ block he could build me a good one. But for my hp goals it wasn't worth it.
Engine Build - Click Here
This is my fourth Subaru tear down. Believe me the first one was a mystery on how to get the pistons and block separated.
Getting a little closer. They sure look nice in their home.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-02150454.jpg
Still working on putting a transmission in my sons WRX at the same time. Here is what the garage looks like at the moment.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-06-28220715.jpg
man I have three bays and three storage lifts in my garage and I'd much rather be in yours. my father is merely a collector and always gives me shit when I try to wrench on my car in the garage. can't wait to do my short block install and hopefully 6mt drivetrain swap all at the same time. good luck with the build seems like you've been around the block once or twice with these
You not going to get the block faced before the heads go on?
Took them to work and indicated the surface. Still flat within .001. Good enough.
Do you plan to port the heads and norrow the dividers ?
I had my buddies machine shop do that to mine.
I am not doing any head work at this time. The heads are shimmed and new cams are ready for install. After having to replace the heads and the block, funds are just running low. It should still be fun and it will be my daily driver. It's not a problem pulling the engine anyway, just in case I need MORE:).
Last couple of days have been hotter than hell in the midwest. I stayed in the house with the air on.
Got out today and did some more assembly.
Oil pick up and plate installed.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06201610.jpg
Oil pan.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06204334.jpg
Cosworth oil pump.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06205218.jpg
ARP studs.
http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06213206.jpg
I wish my garage looked like yours and my wife is happy it does not. Looks like a great build. Thanks for the pics.
My wife does not like my garage either. Too messy for her taste.
More pics to follow as time permits. Yard work waits for no one and I have 2 acres of grass to cut.
