Evnldr Posted October 4, 2013 Share Posted October 4, 2013 Looking over the search threads cant find other than ring lands.. what causes my IAM .875 . Stock, only thing I have added was a boost gauge,, for the hell of it I removed it and same result. I have attached a log waiting on my new cable to do a LV. don't want to hurt aything.. If I should log anything to help let me know. I do have a ticking but I seem to remember its normal. Its a 2005 5eat with 36K on it. Maybe its something I have overlooked. I looked at the maf looks clean. http://www.evnldr.com/CCTV/romraiderlog_20131003_065945.csv Link to comment Share on other sites More sharing options...
heiche Posted October 4, 2013 Share Posted October 4, 2013 Please post a LV when you are able, that will help to see the "big picture". As far as your RR log goes, I'm not seeing much as far as knock. However, your fuel corrections seem to have large swings. Possible boost leak? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Evnldr Posted October 5, 2013 Author Share Posted October 5, 2013 Another quick log.. One day I will learn to read them more proficient Evnldr2.csv Link to comment Share on other sites More sharing options...
iNVAR Posted October 5, 2013 Share Posted October 5, 2013 Didn't I tell you what to log? You're logging a bunch of unnecessary stuff and not logging a bunch of necessary stuff. Link to comment Share on other sites More sharing options...
Evnldr Posted October 5, 2013 Author Share Posted October 5, 2013 Yes but I forget stuff, and I forgot to save a profile for it. Looking over past post I'm going to say you said to log the following: A/F Learning #1 (%) Boost Error* (psi) Engine Load (4-byte) Engine Speed (rpm) Feedback Knock Correction (4-byte)* (degrees) Knock Correction Advance (degrees) Knock Correction Advance (IAM only)* (degrees) Knock Sum* (count) Manifold Relative Pressure (4-byte)* (psi relative) Mass Airflow (g/s) A/F Sensor #1 (AFR) IAM (4-byte)* (multiplier) Ignition Total Timing (degrees) In Gear Look good? Will see how many I can get before I have to kick some out. Link to comment Share on other sites More sharing options...
iNVAR Posted October 5, 2013 Share Posted October 5, 2013 You're missing FLKC (1-byte). Change the FBKC to (1-byte) also. And you need Primary WGDC. Link to comment Share on other sites More sharing options...
Evnldr Posted October 5, 2013 Author Share Posted October 5, 2013 Ok here it is, small log. but all should be there.romraiderlog_Porn_20131005_020813.csv Link to comment Share on other sites More sharing options...
iNVAR Posted October 5, 2013 Share Posted October 5, 2013 lol, I'm gonna hurt you... Manifold RELATIVE pressure. Also add in Throttle Opening Angle. Try to get that LV. It helps a lot. There doesn't appear to be any large amounts of knocking anywhere except maybe around 2600-2800 at 1.4-1.5 load.... Your IAM is already reduced so the fact that you're still pulling timing could mean there's a problem there. I sort of want to tell you to reset the ECU and go log again after IAM reaches 1 (you have to drive around a bit after a reset to get it back to 1). But resetting your ECU wipes out your LV, and I really want that LV first.... Link to comment Share on other sites More sharing options...
caramall2 Posted October 7, 2013 Share Posted October 7, 2013 Not to hijack, but what conditions besides knock reduce IAM? Do fuel trims or anything do that in and of themselves, or just knock? Overboost? Just curious. Link to comment Share on other sites More sharing options...
iNVAR Posted October 7, 2013 Share Posted October 7, 2013 Knock, that's it AFAIK.... other than resetting the ECU if the map is set to start at < 1 for safety reasons and then work its way up to 1. Link to comment Share on other sites More sharing options...
caramall2 Posted October 8, 2013 Share Posted October 8, 2013 Thanks. That's what I assumed. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 8, 2013 Share Posted October 8, 2013 Little trick: put your car into 3rd or 4th, about 2,000rpm and give it consistent 30% throttle angle and if your car is running properly, this usually will get your IAM to 1 quickly. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 8, 2013 Share Posted October 8, 2013 You're missing FLKC (1-byte). Change the FBKC to (1-byte) also. And you need Primary WGDC. iNVAR, Curious why you like to log the lower byte rate for fbkc and flkc? I like to log both a 4 byte. I know it takes some extra read speed, but with those parameters, I like to ensure nothing is missed. I can see if logging is being done with a vag-com cable the need to drop to the lower reading speed, but the Tactrix cable seems to handle it fine. (the 5th gen's ecu reads even faster). I'm not questioning your abilities, just curious www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
iNVAR Posted October 8, 2013 Share Posted October 8, 2013 1-byte/4-byte doesn't (or it shouldn't) affect resolution or ability to catch a knock...only the precision. I treat FLKC and FBKC as parameters where if I knock, it's good enough for me to know that I knocked and how (FBKC vs FLKC.... this is why I knock both in addition to Knock Sum), and not necessarily the degree that I knocked. If I knock and FBKC pulls -2.11 vs. -3.84 (I think that's it) I don't really care. I just know that there's knock and I should look into it at least and see if it reoccurs. Further, I don't think that the difference in precision between 1-byte and 4-byte is enough to cause a knock to register as -3.84 under 4-byte but only -2.11 under 1-byte. As such, I would rather squeeze out more resolution by reducing the amount of bandwidth required. I also use IAM 1-byte for the same reason. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 9, 2013 Share Posted October 9, 2013 Fair enough, I appreciate your explanation. I like understanding other people's reasoning. The 07 and newer read at a higher rate, so I generaly log 4 byte on both flkc and fbkc. Not a bad idea though to go lower with the 05-06. Sent from my SAMSUNG-SGH-I747 using Tapatalk now Free www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
Evnldr Posted October 11, 2013 Author Share Posted October 11, 2013 I sort of want to tell you to reset the ECU and go log again after IAM reaches 1 (you have to drive around a bit after a reset to get it back to 1). But resetting your ECU wipes out your LV, and I really want that LV first.... Going to be a while on the cable... seller sent the same shit cable even after saying it was the correct one. So should I just pull it and give it a week to correct it's self? Link to comment Share on other sites More sharing options...
Evnldr Posted October 16, 2013 Author Share Posted October 16, 2013 **** Update ****** Here is a Log.. now Im back at 1. Not sure why.. But here is my new log..romraiderlog_whoohoo_20131016_113241.csv Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 16, 2013 Share Posted October 16, 2013 still left out fbkc, but nothing really odd for a stock map pull. Only knock event appears right after letting off after WOT. Boost is a bit low. Target is 13.54psi from 2,400rpm to 3,600rpm. Nothing of major concern though. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
