ttshooter Posted October 3, 2009 Share Posted October 3, 2009 I have a 2000 Legacy with the engine check light on. I changed out the gas cap & it is still on. What else could it be? thnaks Todd Link to comment Share on other sites More sharing options...
quicklook2 Posted October 3, 2009 Share Posted October 3, 2009 have someone read the codes. it could be a million things. why would you think the gas cap was bad? Link to comment Share on other sites More sharing options...
ttshooter Posted October 3, 2009 Author Share Posted October 3, 2009 the owner's manual noted that it could be the gas cap. Link to comment Share on other sites More sharing options...
quicklook2 Posted October 3, 2009 Share Posted October 3, 2009 it says to tighten it, not replace it. Link to comment Share on other sites More sharing options...
ALTER Posted October 4, 2009 Share Posted October 4, 2009 how would i go about having someone read the coeds? Link to comment Share on other sites More sharing options...
ehsnils Posted October 4, 2009 Share Posted October 4, 2009 Get a code reader or go to a garage where they are able to read OBD-II codes. Since you are in Saudi Arabia I won't say Autozone! Link to comment Share on other sites More sharing options...
quicklook2 Posted October 4, 2009 Share Posted October 4, 2009 is the car running bad? if not, reset the computer ansd see if the light goes on again. Link to comment Share on other sites More sharing options...
ttshooter Posted October 5, 2009 Author Share Posted October 5, 2009 remove the battery cable resets the computer??? Link to comment Share on other sites More sharing options...
quicklook2 Posted October 5, 2009 Share Posted October 5, 2009 you need to get a manual. you need to use google to search for things like this. for today here is the answer: Sorry to dig up an old thread, but... Heck YA!!!! I finally got around to resetting the ECU (or some called it the ECM): Run till operating temp is reachedWrite down all your radio settings/presetsDisconnect batteryPump break petalTry to start (drains any capacitors holding any power to clear the ECU memory)Turn off the ignition, and remove key (this makes sure the ECU won't get hit with a power surge on the next step)Connect batteryTurn on ignition (do not start engine)Pump accelerator slowly 3 or 5 times, this teaches the ECU the range of the throttle position sensor (TPS)Start engineLet idle for a bitTurn on A/C (allows the ECU learn that there is A/C installed)Reprogram your radio settings/presets i hope this helps you out. you did not say if it is running badly or any other info on vehicle like mileage , how long light was on, what else did yout try, any changes in the vehicle, etc. this would help people help you. Link to comment Share on other sites More sharing options...
ttshooter Posted October 6, 2009 Author Share Posted October 6, 2009 runs good, no difference, 120k, only thing I have done to the car is change out the alt. (the alt. light did not let me know that it was not charging). the check engine light was coming on & off before I changed out the alt. now just stays on. thanks Link to comment Share on other sites More sharing options...
quicklook2 Posted October 6, 2009 Share Posted October 6, 2009 i would clear codes. see if it happens again. Link to comment Share on other sites More sharing options...
ConnertheCat Posted October 6, 2009 Share Posted October 6, 2009 Could be bad gas, effected my 2000 a week or two ago. Link to comment Share on other sites More sharing options...
