mdennett99 Posted May 10, 2011 Share Posted May 10, 2011 So its been determined that the 06-07 WRX 4 pots are not an upgrade. But what about the rears? LGT and WRX rear rotors are the same size. So wouldn't a mono block style caliper be better than a slide style? And yes I searched, only info about the fronts come up Any ideas? Has anyone tried it and with what results? Link to comment Share on other sites More sharing options...
mdennett99 Posted May 11, 2011 Author Share Posted May 11, 2011 Anyone? Link to comment Share on other sites More sharing options...
teK-- Posted May 12, 2011 Share Posted May 12, 2011 Check the piston size of the two calipers, that'll answer your question. I doubt reduced flex in a Monoblock compared to slider caliper is going to be that noticeable in the rear of the car. Also one thing to double check is that I remember reading somewhere that the brake hose banjo connection is different orientation between WRX and Legacies, so you may need to get WRX brake lines as well. Link to comment Share on other sites More sharing options...
