Minahands Posted July 19, 2014 Share Posted July 19, 2014 I have purchased a a metra head unit chassis to replace the one that was previously in my car. http://i.imgur.com/l4h7v7B.jpg However the wiring has me confused. I have the appropriate harness for the wiring loom however there are two wires (grey and black) that go directly into the head unit and cannot be removed. I am not sure if these are power cables or antenna. http://i.imgur.com/tQq6tnT.jpg There is also a grounding wire which feeds back into the loom which I'm assuming will no longer be needed. Also a lack of an antenna input. http://i.imgur.com/J42GY6r.jpg?1 The head unit that I'm installing in the car is and Alpine CDE-143BT. However I'm not sure how I should be removing the original head unit since it is wired in. And once I do have it out where do I get an antenna signal from? The head unit model number is Kenwood GX-201KNF2. A link to the manual is below. https://drive.google.com/file/d/0By89y4FQpGC7YTV2X0NvMzVwaE0/edit?usp=sharing Link to comment Share on other sites More sharing options...
Minahands Posted July 22, 2014 Author Share Posted July 22, 2014 Bump, Anybody have any ideas? Link to comment Share on other sites More sharing options...
SVXdc Posted July 22, 2014 Share Posted July 22, 2014 The gray and black "wires" are actually dual coax AM/FM antenna cables. The gray plastic block is a junction between the car's antenna plug and the radio's antenna socket. See this thread for pictures and info. Your radio's cables are not as long -- that thread shows a newer model (2010-up). But your car's connector is identical. Do not pull the coax wires! You need a Subaru antenna adapter -- Aerpro APA52, Metra 40-SB10, or similar. You don't need the long version. The Metra dash kit was intended for LHD cars. You'll need to do a little extra work for your hazard switch (same as what people with LHD cars with automatic climate controls must do to install the JDM HVAC dual-DIN kit). Link to comment Share on other sites More sharing options...
Minahands Posted July 23, 2014 Author Share Posted July 23, 2014 Thank you, I preemptively bought that metra cable anyway incase I had to splice into one of the wires. Glad I don't have to. I'll reattempt this when the cable gets here and report back. Link to comment Share on other sites More sharing options...
