SkiDaddy Posted January 13, 2006 Share Posted January 13, 2006 I searched and found nothing usefull, so here's the question: I took delivery of my new '06 LGT Tuesday. I've noticed what seems to me to be excessive wind noise from the windshiled area, maybe the base of the windshield? It's hard to pinpoint. This morning on the way in I tried to quantify it; at 80 the noise is ~just~ a bit louder than one step below maximum fan speed noise (recirculate off, fresh air coming in) and less than max fan speed noise. It goes up and down with crosswind gusts, so it's not tire noise. How does this compare to everyone else? Link to comment Share on other sites More sharing options...
jlce88 Posted January 13, 2006 Share Posted January 13, 2006 I'll bet it's the air coming in through the scoop and into the IC Link to comment Share on other sites More sharing options...
executor485 Posted January 13, 2006 Share Posted January 13, 2006 Your windshield is going to crack... Mwauahwhwahahwaaaa.... Im still bitter about mine and have yet to get it fixed...lol. I dont have any wind noise though. Maybe a bad seal around one of the windows or doors? If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
forestir Posted January 13, 2006 Share Posted January 13, 2006 I've read about this usually being from the side view mirrors, where they mount to the door. The area might not be sealed perfectly--I guess that area is very sensitive to even the slightest imperfections. You might want to eyeball it for any seams or gaps. Link to comment Share on other sites More sharing options...
Drakuun Posted January 13, 2006 Share Posted January 13, 2006 I've read about this usually being from the side view mirrors, where they mount to the door. The area might not be sealed perfectly--I guess that area is very sensitive to even the slightest imperfections. You might want to eyeball it for any seams or gaps. +1 The Mirror grommets (the rubber sheath's that house the window when it's up, and that the mirros attach to) were prone to wind noise on the older body styles.. my '03 does it quite a bit, I find heating it up, and pressing the interior side of the grommet against the window helps to quell it.. till I open the door again. Link to comment Share on other sites More sharing options...
jagcars26 Posted January 13, 2006 Share Posted January 13, 2006 +2,,my wifes 06 leaks some air at that point also,,wihile driving, try just mushing the window molding near the mirror from the inside. Worked on here car. Link to comment Share on other sites More sharing options...
SkiDaddy Posted January 13, 2006 Author Share Posted January 13, 2006 OK, thanks guys, I'll try that. Link to comment Share on other sites More sharing options...
Drakuun Posted January 13, 2006 Share Posted January 13, 2006 Might also try making sure that the doors are installed properly and not cocked one way or the other. I honestly think my noise is because my door hang is a little off, but I haven't gotten a bug in my butt to take it off and rehang it. Try snugging up the Latch too, make sure it's square and not off kilter. Link to comment Share on other sites More sharing options...
recuomo Posted January 14, 2006 Share Posted January 14, 2006 You can search this site and probably find my posting from last year a few weeks after I took delivery of my '05 sedan. I heard noise going as slow as 10 mph. Well today they finally found the true source of my "wind" noise. It was coming from the top of the windshield not being sealed properly when it was installed. The service manager said you could push from the inside and the glass would move! They are replacing it with a factory new windshield, said they didn't want to take a chance re-sealing the old glass. Kudos to Metric Motors! Link to comment Share on other sites More sharing options...
SkiDaddy Posted January 14, 2006 Author Share Posted January 14, 2006 Thanks guys, keep any suggestions coming! I'm gonna need to get someone else to drive whilst I move around & listen. Link to comment Share on other sites More sharing options...
recuomo Posted January 18, 2006 Share Posted January 18, 2006 Well they found a gap of 6" at the top of my windshield where the sealant wasn't applied. They are guessing the robotic arm ran out of sealant while they were installing the windshield in my car. Link to comment Share on other sites More sharing options...
Xantium Posted January 18, 2006 Share Posted January 18, 2006 I think my wind noise is coming from some f'ed up plastic guide/piece type things on the sides of the hood cowl just below the windshield. You'd have to take a look at yours to know what im talking about but the drivers side is aligned way differently than the passengers. Link to comment Share on other sites More sharing options...
eldiablo Posted January 18, 2006 Share Posted January 18, 2006 Check for beer cans in or around the windhield area... My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
SkiDaddy Posted January 18, 2006 Author Share Posted January 18, 2006 I've seen the pieces you're describing Xantium. I actually removed the sealing strip at the junction of the windshield/plastic piece to look at it. When time allows I'm going to remove all that plastic (it's just held w/push pins) & use painters tape to masl all around the windshield, get 'er up to 80 & see if that makes any difference. I'll let you all know. Link to comment Share on other sites More sharing options...
recuomo Posted January 23, 2006 Share Posted January 23, 2006 Well I finally picked my car up after Metric replaced the windshield and thankfully no more wind noise! As previously posted, the factory missed about 6" of sealant across the top but Metric decided to replace the whole windshield for me. Link to comment Share on other sites More sharing options...
b4wantab Posted January 23, 2006 Share Posted January 23, 2006 For those that have wind noise from the mirror gusset area I have the fix for the BH series. The DSM showed this to me and it works great, no noise in a year or so. This is for the BH and similar models I am unsure about the newer gussets. The noise is from a gap between the outside vertical rubber seal on the mirror body and the glass. Open the door. Roll down the window. Pull off the black plastic triangular trim piece. It is held on by little nipples, get your finger nails under an edge and pull it off. Notice the gap between the outside rubber seal and the inside seal. Interlock your fingers, like you are going to pray. Place your palms on each side of the gusset. One on the inside, one on the outside. Squeeze your palms together to make that gap between the inside and outside seal as small as possible, if not zero. Roll the window back up and go for a ride. There was a TSB about the gussets flexing and getting noisey. They had a redesigned gusset that was stronger but it flexes over time also. So the DSM said this is the best fix. If the noise if from the mirror area this may work. Peace, Greg Link to comment Share on other sites More sharing options...
SkiDaddy Posted February 27, 2006 Author Share Posted February 27, 2006 Follow up - I had the good folks at Subaru of Jacksonville listen to the noise, & they agreed immediately something was wrong & scheduled a windshield replacement under warranty. It was done Friday & I'm VERRY happy to report the noise is completely gone! :icon_bigg :icon_bigg :icon_bigg Link to comment Share on other sites More sharing options...
Deer Killer Posted February 27, 2006 Share Posted February 27, 2006 hmm.. both I and my friends legacy have the noise as you described. Do you now not hear any cross-wind like noise at 80? Link to comment Share on other sites More sharing options...
SkiDaddy Posted February 27, 2006 Author Share Posted February 27, 2006 Yes, some cross wind buffeting remains, but it's significantly quieter now. When driving at 80 w/no crosswind it's Audi quiet. Link to comment Share on other sites More sharing options...
06Leg Posted February 27, 2006 Share Posted February 27, 2006 Just bought my 06 a few days ago, and I notice this noise at the top of the windshield at speeds as low as 40mph. Is there a TSB for this I can refer to when talking to the dealer? Thanks! I hope this isn't a sign of things to come.... 06 Legacy 2.5i SE. Link to comment Share on other sites More sharing options...
SkiDaddy Posted February 27, 2006 Author Share Posted February 27, 2006 Yeah, I could hear mine as low as 45. No TSB as far as I can tell (or the dealer could find) for Legacies; I think there was one for the forrester. Link to comment Share on other sites More sharing options...
06Leg Posted February 27, 2006 Share Posted February 27, 2006 Ugh, I hate the idea of a new windshield. Greasy pawprints all over, all sorts of broken seals, most likely MORE noise as a result... Hoping for an "easy" fix! Link to comment Share on other sites More sharing options...
SkiDaddy Posted February 27, 2006 Author Share Posted February 27, 2006 The guy who did mine was a professional, a few fingerprints, NO wind noise! Link to comment Share on other sites More sharing options...
06Leg Posted February 27, 2006 Share Posted February 27, 2006 Ski - Can you tell me what dealer did yours? In case my dealer wants to call them for assistance? Link to comment Share on other sites More sharing options...
SkiDaddy Posted February 27, 2006 Author Share Posted February 27, 2006 Subaru of Jacksonville. Highly recommended. Link to comment Share on other sites More sharing options...
