BDII's DIY grill walk through (ton's of pics)
I couldn't bring myself to pay $250 for the RBS, or $150 for an ebay knock off that never fits, so I decided to make my own.
I've never done anything like this before so it was def a learning experience :lol:
This is how I did it....
THINGS YOU WILL NEED
1. Dremel or the like and a accessory kit
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01551.jpg
2. Sand Paper, 3 levels, light, medium and heavy
3. Screw Driver
4. Super glue
5. Eye protection
6. spray paint (primer, metallic color and clear coat)
7. Bondo kit
8 metal body patch
9. Gutter, honey comb mesh (6" x 2')
10. zip ties
11. Paper clips :confused::lol:
STEP 1
Use the dremel to remove the inside:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01553.jpg
This is the hardest part.... have patience and do this in a well ventilated area.
Step 2
Use the grinder tool to smooth all of the edges, be careful not to grind to deep or you will have to fill in the holes.
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01555.jpg
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01556.jpg
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01554.jpg
Once your satisfied with your sanding and all of the edges are smooth. Take a shower. no really... put the grill under running water to remove all of the dust.
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01557.jpg
Step 3
BONDO TIME!!!! make sure you do this in a well ventilated area or you will get sick or high or a combination of the 2 :lol:
Take the metal patch and place it over the four holes and cut to size:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01558.jpg
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01559.jpg
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01560.jpg
next, paper clip them on, this will hold them in place.
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01565.jpg
Now this is the tough part..... BONDO over the paper clips.... you have to wait no more than 5 minutes then pull the paper-clips off before the bondo sets.... if you don't :spin: you will have to saw them out. The BONDO should hold the mesh and break apart to let the clips out.
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01561.jpg
Step 4
Once the bondo dries, sand it down using the dremel with this bit
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01569.jpg
be careful not to go to deep, use the sand paper if needed.
it should end up looking like this
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01572.jpg
Step 5. Once all the bondo is done, drill holes on the top inside for the zip ties to attach the mesh like this:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01568.jpg
Step 6
Sand again with high grit, them medium grit, then low grit
Wipe down the grill with a moist cloth to remove all of the dust.
Step 7
Apply 3 thin coats of primer, ensure the entire grill is covered and you can't see any chrome or black plastic, do the same to the mesh, let dry
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01575.jpg
Next, apply 3 good coats of the color of your choice, let dry
Next, apply 3 good coats of clear coat, let dry.
Need forum help? Private Message legGTLT
  • Replies 102
Step 8
It's mesh time!!
Place the mesh on the backside of the grill and bend to form, trim the excess.
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01580.jpg
next, attach the zip ties to the mess through the holes you made, ensuring a snug fit!
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01579.jpg
I didn't use anything on the bottom, you can super glue it if you like, but this is tedious.... and smelly.
This is what is ended up looking like:
Before
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01582.jpg
After:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01584.jpg
Before and after
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01581.jpg
Excuse the finger prints.. they wipe off :lol:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01585.jpg
Try not to stab yourself with the screw driver whilst removing pop its :lol:
http://i44.photobucket.com/albums/f43/Bu11dogg2/DSC01586.jpg
good job. when you going to start taking orders? My old grill needs some work. it was modified by Subastyle; looks similiar to yours.
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
I'm in the process of getting vendor status, waiting on Tide to get back to me.
If and when I do..... $100 shipped for the grill or $80 plus your stock.
I won't do Red... to hard to color match.
I can also attach subaru/Sti/L7 or any other badge at no additional cost if you proved the emblem
+1 on your workmanship
-1 on the look...
Put the logo in the center or something!
The logo is going on once the rain stops :)
Once you get that vendor status, let me know where I can send mine. Too lazy to do it myself, and am unhappy with the way my JDM grill fits
Is sure will ;)
come on guys he put a lot of work into this and i would like to see the thread stay i feel it will help others who want to try this also if he gets vendor status and sells some of them thats fine to. thanks bosco
Stay Stock Stay Happy
  • 2 months later...
Nice work, but i had a different way of approaching it... i didnt want to spend the money on buying a factory one so i customized mine. Instead of bondoing the channels, im using a dremel to cut an even amount out all the way around the edges. it will have a shorter base, but less hassle(for me). then, as you did, i have gutter guard for the backing and painted it flat black. To finish, im going to put "SUBY" or "LEGACY" across the bottom right corner with lettering that i took from the trunk. I'll post pictures as soon as i take them!!
actually trimming the grill down is a good idea
i filled in the bottom gap with a piece of plastic i cut from a plastic paint pallet i picked up from hobby lobby.. it was the same thickness as the grill.. so i glued it in and barely had to use any bondo to fill where it was.. no worries about cracks later on
512whp/465ftlb 2005 5EAT Legacy (Build Log)
Videos -
