need bb Posted July 26, 2014 Share Posted July 26, 2014 I have changed my brake pads in my Impreza without any issues, but the Legacy's is proving more difficult:mad: I am having some trouble with the brake pads clips. Should the clip be in the first (outside) or the second (inside) slot on the caliper anti-rattle clip? http://media.csh.rit.edu/Car/IMG_0662.JPG I read the brake pad install guide on the forum and it was recommended to insert the tab only part of the pad first. I tried this but was unsuccessful as when I tried to insert the side with the clip there wasn't enough clearance to clear the caliper's anti-rattle clip. Am I doing something wrong? I am used to pads taking 30 seconds to change, but it took me 10 minutes with an extra set of hands just to get this one pad in. http://media.csh.rit.edu/Car/IMG_0659.JPG Thanks Link to comment Share on other sites More sharing options...
MeoW71 Posted July 27, 2014 Share Posted July 27, 2014 It isn't supposed to hook in like that. Pad is upside down, and that tab on the pad goes on the outside, pressing against the tab on the bracket. I can't find the picture of how it supposed to be installed. Here we go: http://legacygt.com/forums/showthread.php/brake-pad-return-spring-21887.html Link to comment Share on other sites More sharing options...
Dispatch20 Posted July 27, 2014 Share Posted July 27, 2014 It isn't supposed to hook in like that. Pad is upside down, and that tab on the pad goes on the outside, pressing against the tab on the bracket. I can't find the picture of how it supposed to be installed. Here we go: http://legacygt.com/forums/showthread.php/brake-pad-return-spring-21887.html ^^ This gentleman is correct! Take the other outer pad in the set and install it in on the side you took the picture of. The spring tab will be facing down and it slots against the anti-rattle/slider part of the bracket. OP - if you are still confused post back and more clarification can be added if you need. Link to comment Share on other sites More sharing options...
need bb Posted July 27, 2014 Author Share Posted July 27, 2014 Thanks for the PDF. I should have taken note when I disassembled everything. Link to comment Share on other sites More sharing options...
need bb Posted July 27, 2014 Author Share Posted July 27, 2014 Is this correct? There was a couple things I still am not 100% sure on: -If I let go of the pad the spring tab pushes the pads out. Is this right? -Does the wear indicator go inside the caliper clip as shown below? http://media.csh.rit.edu/Car/IMG_0839.JPG http://media.csh.rit.edu/Car/IMG_0840.JPG Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2014 Share Posted July 27, 2014 Yes. That is correct. I have cut them off also. If you watch your brakes, you don't need those. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bluesuby Posted July 27, 2014 Share Posted July 27, 2014 Thanks for the pictures. Those sketches from the shop manual don't tell much. Link to comment Share on other sites More sharing options...
need bb Posted July 27, 2014 Author Share Posted July 27, 2014 Is there any tips to get the pads to go in? I needed to use a screw driver to bend the caliper clips so the pads would clear. Link to comment Share on other sites More sharing options...
apexi Posted July 27, 2014 Share Posted July 27, 2014 I'm confused, even with the new pictures isn't that the pad that goes on the back of the rotor? I don't think I've ever see pads that go on the front of the rotor that have clips like that. *I just looked at the FSM page in the link, and I guess some pads do have those clips on the outside? Your picture does look like the fsm illustration. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2014 Share Posted July 27, 2014 I have filed the tabs on some pads to get them to slide in the spring clips. I also put a small dab of brake grease on them. The same grease as the pins get. Use Anti-seize compound on all the threads, even the lug nuts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTPpilot Posted July 28, 2014 Share Posted July 28, 2014 I thought it was bad to use any lube on lug nuts as it throws torque values off..... Link to comment Share on other sites More sharing options...
mnstrmech Posted July 28, 2014 Share Posted July 28, 2014 I thought it was bad to use any lube on lug nuts as it throws torque values off..... That is true. NEVER lubricate lug nuts and the studs... EVER. If you get a bit of corrosion, i just run them thru the appropriate tap/die to clean the threads. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2014 Share Posted July 28, 2014 I thought it was bad to use any lube on lug nuts as it throws torque values off..... That is true. NEVER lubricate lug nuts and the studs... EVER. If you get a bit of corrosion, i just run them thru the appropriate tap/die to clean the threads. Old wifes tail. Been doing this on all the cars I've worked on in the past 15 years or so. Don't believe everything you read. I also torque all the lug nuts to 80ftlbs. From the 3500 Chevy that towed the 40ft 5th wheel to the 147mph Civic drag race car. What is the torque valve for thses cars lug nuts anyway's ? I've been using 80 ftlbs since the mid 1980's. You do know to torque them twice, right ? Once with a little weight on the tire then lower the jack and torque them again. Check again after 25 miles or so. The use of anti-seize on the lugs in not that much of a difference to worry about. It has been discussed on here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Jazz95 Posted July 29, 2014 Share Posted July 29, 2014 +100 for Max. Been doing it for years, and it makes wheel removal extremely easy. I anti-seize every bolt I've ever removed/installed. Link to comment Share on other sites More sharing options...
GTPpilot Posted July 29, 2014 Share Posted July 29, 2014 I'll buy that you can probably get away with it, however, 80 ft-lbs applied to a lubed thread is not the same as 80 ft-lbs applied to a dry thread. I would be concerned about having only 80 ft-lbs on a lubed thread, but I worry too much about everything and admit to not being a fastener design expert. Edit: Actually, just realized 80 on a lubed thread would stretch a stud more than a dry thread. Oops. 80 is probably fine in that case especially when you consider the air gun situation below. I do know they factor this stuff in when designing assemblies with fasteners and torque values. Good question on when the value should actually be. I've always used 80 to 90 ft-lbs on lugs...dry. Torque best I can off the ground in an alternating fashion, then again on ground....then again after a heat cycle. Drives me nuts when a shop just blasts them on with an air gun. I guess 200 ft-lbs must not harm anything....... Anyway, sorry to get off topic. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2014 Share Posted July 29, 2014 If the shop is good, they will use torque sticks. Which come in colors for different torque values. I have seen them used at my "trusted mechanic's" shop. https://www.google.com/search?q=torque+sticks&rls=com.microsoft%3Aen-us%3AIE-ContextMenu&oe=&safe=active&gws_rd=ssl&oq=&gs_l= At home I run the lugs down with my 70ftlbs 3/8 butterfly impact and then use a 1/2" torque wrench to torque them in a star pattern. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
