EvvLGTWagon Posted April 17, 2014 Share Posted April 17, 2014 I have a 2006 Legacy GT Wagon with 5EAT. How can I determine if I have VDC on my car? Thank you for the help in advance. Link to comment Share on other sites More sharing options...
rob-2 Posted April 17, 2014 Share Posted April 17, 2014 You do However it doesn't work. Link to comment Share on other sites More sharing options...
EvvLGTWagon Posted April 17, 2014 Author Share Posted April 17, 2014 Care to explain? I am looking to order the GS brake brace and need to make sure I purchase the correct version Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
cypher0117 Posted April 17, 2014 Share Posted April 17, 2014 You don't have it. VDC = vehicle dynamic control (aka traction control). You'd have a light in your dash if you had it, but 05-06 legacies didn't come from the factory with it Link to comment Share on other sites More sharing options...
rob-2 Posted April 17, 2014 Share Posted April 17, 2014 I thought VDC was in the center diff to send power front or rear as needed? Link to comment Share on other sites More sharing options...
unreal- Posted April 18, 2014 Share Posted April 18, 2014 I thought VDC was in the center diff to send power front or rear as needed? Most Subarus can transfer power front/rear as needed from the factory, its just that they tend to be not as effective in side to side transfer of torque unless they have front/rear LSD. User adjustable front/rear power is only on the STI's 6spd trans. VDC seems to be subaru's form of stability/traction control. Link to comment Share on other sites More sharing options...
lee07 Posted April 18, 2014 Share Posted April 18, 2014 You don't have it, 2007 and newer came standard with it along with the tpms Link to comment Share on other sites More sharing options...
rob-2 Posted April 18, 2014 Share Posted April 18, 2014 Most Subarus can transfer power front/rear as needed from the factory, its just that they tend to be not as effective in side to side transfer of torque unless they have front/rear LSD. User adjustable front/rear power is only on the STI's 6spd trans. VDC seems to be subaru's form of stability/traction control. I thought so as well, I should show you how I can get this puppy stuck with a lifted front wheel Link to comment Share on other sites More sharing options...
stanjk3 Posted April 19, 2014 Share Posted April 19, 2014 I thought VDC was in the center diff to send power front or rear as needed? That's VTD (Variable Torque Distribution). VDC is stability control. http://www.subaruoutback.org/forums/61-general-discussions/11036-vdc-vs-vtd-whats-all-worth.html Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
SleeperScoob Posted April 20, 2014 Share Posted April 20, 2014 So it just means that us 05-06 guys don't have to hold a button down every time we go out to drive our cars. Thank god. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted April 20, 2014 Share Posted April 20, 2014 So it just means that us 05-06 guys don't have to hold a button down every time we go out to drive our cars. Thank god. My 08 spec.B has VDC and I can honestly say I have yet to have it truly spoil a 'drive.' only times it's come on for me is when the road is wet and I was actively trying to force it on. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
BoostSLUG Posted April 20, 2014 Share Posted April 20, 2014 You don't have it, 2007 and newer came standard with it along with the tpms Uhhhh my 07 doesn't have a vdc button anywhere. It also doesn't have vdc because I can get it to slide in any manner I want, dry or wet. Link to comment Share on other sites More sharing options...
rob-2 Posted April 20, 2014 Share Posted April 20, 2014 That's VTD (Variable Torque Distribution). VDC is stability control. http://www.subaruoutback.org/forums/61-general-discussions/11036-vdc-vs-vtd-whats-all-worth.html Oops my error. Link to comment Share on other sites More sharing options...
rob-2 Posted April 20, 2014 Share Posted April 20, 2014 My 08 spec.B has VDC and I can honestly say I have yet to have it truly spoil a 'drive.' only times it's come on for me is when the road is wet and I was actively trying to force it on. I once had to power drift a car on black ice to avoid a major crash. It's the only time I was thankful for not having any nanny gear. Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 20, 2014 Share Posted April 20, 2014 You know where the button is to turn on your side mirror defroster is? If you have VDC, the button will be there. No button = no VDC. I also disagree that it came standards with 07+ LGTs since I have an 08 and I don't have it. http://legacygt.com/forums/attachment.php?attachmentid=111807&stc=1&thumb=1&d=1328563722 Link to comment Share on other sites More sharing options...
Chris GTO TT Posted April 20, 2014 Share Posted April 20, 2014 The only manual transmission 4th gen Legacy that got VDC was the spec.B. It was standard equipment on 5EAT cars starting in 07 or 08 not sure exactly when. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
CrowNaza86 Posted April 21, 2014 Share Posted April 21, 2014 You know where the button is to turn on your side mirror defroster is? If you have VDC, the button will be there. No button = no VDC. I also disagree that it came standards with 07+ LGTs since I have an 08 and I don't have it. http://legacygt.com/forums/attachment.php?attachmentid=111807&stc=1&thumb=1&d=1328563722 That's my car! Link to comment Share on other sites More sharing options...
