Spooie Posted December 12, 2012 Share Posted December 12, 2012 Where the heck is everyone buying these things at? I need to replace the LCA bushings and from what I hear these are a great product. Link to comment Share on other sites More sharing options...
ttnio Posted December 13, 2012 Share Posted December 13, 2012 Rallispec.com for GroupN type bushings. Link to comment Share on other sites More sharing options...
AZP Installs Posted December 13, 2012 Share Posted December 13, 2012 We have found the Whiteline bushings to be a better solution as they allow you to add negative caster to the setup. The group n are also harder to get ahold of. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Spooie Posted December 13, 2012 Author Share Posted December 13, 2012 Thanks guys! Hey Mike, Would using the whiteline bushings and going with negative camber be bad for a stock suspension? Does whiteline make some for negative camber and another set for 0? I will eventually go on to some springs. please excuse my suspension stupidity... Link to comment Share on other sites More sharing options...
sheppo9 Posted December 14, 2012 Share Posted December 14, 2012 Why would you want 0 camber? Somewhere around -1.5 is the go. Link to comment Share on other sites More sharing options...
AZP Installs Posted December 14, 2012 Share Posted December 14, 2012 Thanks guys! Hey Mike, Would using the whiteline bushings and going with negative camber be bad for a stock suspension? Does whiteline make some for negative camber and another set for 0? I will eventually go on to some springs. please excuse my suspension stupidity... I was referring to caster. This is different than camber. The caster refers to the angle the hub is at front to rear. Camber refers to the angle in/out of the struts. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Spooie Posted December 14, 2012 Author Share Posted December 14, 2012 Always learning something, thanks for the info. Which part numbers should I buy then for the Whiteline? I read there was a stock replacement type, I do not want the same situation to happen as with the crappy stockers... Link to comment Share on other sites More sharing options...
AZP Installs Posted December 15, 2012 Share Posted December 15, 2012 Always learning something, thanks for the info. Which part numbers should I buy then for the Whiteline? I read there was a stock replacement type, I do not want the same situation to happen as with the crappy stockers... The price difference for the stock replacement type (no caster change) is <$20 so I would suggest just purchasing the adjustable caster ones. You would want the: KCA334 (Front Control Arm Lower Inner Rear Bushing) W0506 (Front Control Arm Lower Inner Front Bushing) Please shoot us an e-mail or call and we can have them shipped out to you ASAP. Thanks. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
