Deadleave Posted September 29, 2010 Share Posted September 29, 2010 I do driving logs once a month and maybe every 2 week or so take a learning view cap. Nothing has changed in the last 10 days in the engine. The IAM has dropped to 0.875 and I at least know its supposed to stay at 1. Any ideas ? I hate to keep going back for expensive retunes, but i dont know if its a tunning issue or something broke. I am still making boost, peaked at 18.41 this morning. Thanks for any insight. Link to comment Share on other sites More sharing options...
keithk831 Posted September 29, 2010 Share Posted September 29, 2010 Well the car is trying to get it back to 1 (see all the blue numbers). But you have some knock instances that are causing it. What kind of mods/tune do you have? Link to comment Share on other sites More sharing options...
Deadleave Posted September 29, 2010 Author Share Posted September 29, 2010 non-stock: Invidia up, ERZ catted DP, 3" exhaust stock: turbo, tmic, k&n panel filter pretty standard stage 2. thanks Link to comment Share on other sites More sharing options...
rtbrjason Posted September 29, 2010 Share Posted September 29, 2010 When was it tuned? I retuned my setup going into summer as I added a few parts and I started seeing some knock as it got colder. Link to comment Share on other sites More sharing options...
Deadleave Posted September 29, 2010 Author Share Posted September 29, 2010 last tune was Sept 2nd ,in 75 degree weather. Isn't cold weather better against knock, I mean the air is colder so...less work on the intercooler ? Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 29, 2010 Share Posted September 29, 2010 Could be bad fuel. Weather hasn't changed that much. A little cooler but temp com table should not have an effect yet or changed compensation. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted September 29, 2010 Share Posted September 29, 2010 Have you cleaned your maf sensor and air filter recently? www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 29, 2010 Share Posted September 29, 2010 I had a second look at those LVs over the past month. You have some random knock in some spots. How many miles do you drive the car in a week? Is it highway miles or stop and go? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Deadleave Posted September 29, 2010 Author Share Posted September 29, 2010 no, nothing has been changed in the last 10 days. I did drive over some nasty bumps in NYC, rough enough to toss the jerk the car about. Large pot hole maybe damaged DP ? I am getting paranoid thinking about all the things that could have hit the underside of the car. I remember now some manhole covers that are stick out out of the road like 4-5 inches, wonder if it hit the DP, and pushed on the turbo ? Should I reset the ECU ? is this a bad idea ? 50,101 miles now, it mixed driving. Ridge; since your in NY, its sawmill to Henry Hudson to west side highway, then streets near Columbia. and back, Also; this is protuned on dyno at EFI logic, who have some top notch rep. Link to comment Share on other sites More sharing options...
Ridgeracer Posted September 29, 2010 Share Posted September 29, 2010 Bumpy roads are not going to trigger a functional knock sensor...IMHO. As for the DP, you would probably have an exhaust leak by now. Your ECU is probably seeing alot of knock spread across the map. Even prior to the drop in DAM/IAM you had knock in at least two cells. Best thing to do is reset the ECU, stay away from WOT runs and do a long datalog of total timing, knock sum, throttle plate opening, engine load, and rpm. Drive like normal and you should be able to capture where in the map its occuring. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Deadleave Posted September 30, 2010 Author Share Posted September 30, 2010 Will do the logs.... also, I rarely go WOT, just some occasional hard accelerations Again thank you so much for the help and info. I would love to tune my own car.....such a steep learning curve. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 30, 2010 Share Posted September 30, 2010 bumps in the road will most defiantly trip a knock sensor.... but only if you are WOT I think you have a tune that just knocks occasionally. I'm gonna take a guess that you were either E-tuned or road tuned. It could be false knock as well. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
rtbrjason Posted September 30, 2010 Share Posted September 30, 2010 last tune was Sept 2nd ,in 75 degree weather. Isn't cold weather better against knock, I mean the air is colder so...less work on the intercooler ? There is an IAT compensation table for timing that adds timing in cooler weather and subtracts it in warmer weather. If you were tuning in heat and then it got cooler you could be adding as much as 2 or 3 degrees more timing. That's fine and how the stock ecu works, but on a tuned car it may need to be double checked in cooler temps to make sure this table is scaled correctly. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 30, 2010 Share Posted September 30, 2010 it's the other way around... the hotter the day, the safer your tune will be later My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
keithk831 Posted September 30, 2010 Share Posted September 30, 2010 it's the other way around... the hotter the day, the safer your tune will be later My understanding as well. That's why I got my road tune done in 90+ degree weather after driving for an hour. Plenty of heat soak Link to comment Share on other sites More sharing options...
rtbrjason Posted September 30, 2010 Share Posted September 30, 2010 it's the other way around... the hotter the day, the safer your tune will be later That would be generally true without a compensation table or with a 0'd compensation table but if you have a table that is globally adding timing as temps lower and subtracting it as they rise you could see knock in cooler temps that you didn't see in warmer temps. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 30, 2010 Share Posted September 30, 2010 If the tuner is tuning right, those tables are not active while he is tuning. So if the tuner can eliminate knock when it's hot out, it will be far more less likely to knock when it's cooler. Common hot/cold problem we see is someone gets a tune when it's cold, then comes back complaining they're not getting full boost when it's hot. Usually they're at 100% WGDC in the hot and that's all she'll do. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Deadleave Posted October 1, 2010 Author Share Posted October 1, 2010 Bumpy roads are not going to trigger a functional knock sensor...IMHO. As for the DP, you would probably have an exhaust leak by now. Your ECU is probably seeing alot of knock spread across the map. Even prior to the drop in DAM/IAM you had knock in at least two cells. Best thing to do is reset the ECU, stay away from WOT runs and do a long datalog of total timing, knock sum, throttle plate opening, engine load, and rpm. Drive like normal and you should be able to capture where in the map its occuring. Reset ECU, drove home from work in mixed but mostly commuter traffic Long log. Do you guys see anything in particular I should note or bring up to my tuner ? Thanks for looking and all the advice. CSV was over the size limit, so I have uploaded it here. http://www.mediafire.com/file/xa4k6bey56cifzi/romraiderlog_20101001_164643.csv LV on the otherhand looks clean Link to comment Share on other sites More sharing options...
keithk831 Posted October 1, 2010 Share Posted October 1, 2010 Reset ECU, drove home from work in mixed but mostly commuter traffic Long log. Do you guys see anything in particular I should note or bring up to my tuner ? Thanks for looking and all the advice. CSV was over the size limit, so I have uploaded it here. http://www.mediafire.com/file/xa4k6bey56cifzi/romraiderlog_20101001_164643.csv I didn't read through the whole thing, but I can see why your IAM dropped. Scroll through the log, only looking at the knock sum column. It goes from 2 to like 12 really fast. You want to get that tuned out. Post up a new LV screenshot. Link to comment Share on other sites More sharing options...
Deadleave Posted October 1, 2010 Author Share Posted October 1, 2010 Updated with LV I would log more but not sure if its safe to push the engine at this point. also am i reading the logs right?, is it hitting 17 psi @ 2700 rpm ? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 1, 2010 Share Posted October 1, 2010 bumps in the road will most defiantly trip a knock sensor.... but only if you are WOT. Really, show me a log of that. The higher the load, the higher the threshold the ECU needs to consider X db as knock. I have never seen this, and the evidence points more towards the ECU seeing it is knock at low load, not WOT. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 1, 2010 Share Posted October 1, 2010 it's the other way around... the hotter the day, the safer your tune will be later kinda true, but not always, actually a lot of tuners say the opposite. In much colder weather one runs the risk of over-boosting and running our of injector. Both should be tuned properly. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 1, 2010 Share Posted October 1, 2010 Reset ECU, drove home from work in mixed but mostly commuter traffic Long log. Do you guys see anything in particular I should note or bring up to my tuner ? Thanks for looking and all the advice. CSV was over the size limit, so I have uploaded it here. http://www.mediafire.com/file/xa4k6bey56cifzi/romraiderlog_20101001_164643.csv LV on the otherhand looks clean [ATTACH]90713[/ATTACH] The time when knock sum goes from 23 to 24 is the only knock sum that is of any concern. And one increment is not really a big deal. So nothing of MAJOR concern in that log. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
keithk831 Posted October 2, 2010 Share Posted October 2, 2010 the evidence points more towards the ECU seeing it is knock at low load, not WOT. x2 Link to comment Share on other sites More sharing options...
Deadleave Posted October 2, 2010 Author Share Posted October 2, 2010 Thanks, is there any evidence that there might be boost creep ? Its hitting 18.5 psi now near 3300 rpm in 3rd. Thanks, seems like most of the knock is from idle and sitting in traffic....which the ECU should adapt to.... Link to comment Share on other sites More sharing options...
