bkiser Posted May 15, 2014 Share Posted May 15, 2014 I have a 92 Legacy 4WD (non turbo) manual trans, and about 2 weeks ago I was cranking it to get it back on the road, it's been sitting about 2 years. I have cranked it up about every month or so and just took a short drive to keep it running. Anyway the last time it ran at all (about 2 weeks ago) when I cranked it up it started right up but I noticed it was running on 3 cylinders, I let it warm up hoping it would clear, then drove about 2 tenths of mile, still 3 cylinders, pulled back home, parked it in driveway and tried to start it again about 5 mins later and it is completely dead, no ignition at all, just normal turn over (no free-wheeling) like a broke timing belt just normal starter speed. Pulled plugs=no spark, bought Coil pack, still dead, not even attempting to fire. It does have 311267K miles but I've heard of the EJ22E's going much longer. Anyone who might have a suggestion or ideas would be greatly appreciated. I love my Legacy and want to get it running again! Thanks, Brandon Link to comment Share on other sites More sharing options...
USLiberty Posted May 16, 2014 Share Posted May 16, 2014 Start with the ignition. Does your coilpack have 12v power with the ignition on, you can unplug it and one wire should be hot. I would get a haynes repair manual, it shows how to troubleshoot the ignition system and anything else you come across Link to comment Share on other sites More sharing options...
bkiser Posted May 18, 2014 Author Share Posted May 18, 2014 Thank You for the suggestion, will try! Link to comment Share on other sites More sharing options...
snederhiser Posted May 19, 2014 Share Posted May 19, 2014 Hello; Did you pull the codes on the ECU? Would also look at the cam and crank sensors. Pull the timing covers and have a peek. How did the spark plugs and wires look, checking for carbon tracks. Steven. Link to comment Share on other sites More sharing options...
