696spd Posted May 23, 2012 Share Posted May 23, 2012 Going to installing my Koni/Rallitek set up soon and want to raise the rear since I keep a lot of stuff in my trunk. One goes between the spring and strut the other between the strut and body. Which method has the least impact on the performance and original design of the spring ? Thanks Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 23, 2012 Share Posted May 23, 2012 Saggy butt spacer. Using an extra pad could make it so the strut bottoms out before the spring binds, which will almost certainly destroy the strut. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
696spd Posted May 24, 2012 Author Share Posted May 24, 2012 Thanks, the spacers are a little more money but worth it. Link to comment Share on other sites More sharing options...
gone2vegas Posted June 5, 2012 Share Posted June 5, 2012 Don't forget to get longer studs if you get the thicker spacers. I forgot the Dorman part#, but they're the wheels studs for a Chevy Metro. Whoever you buy the spacers from should have them. Link to comment Share on other sites More sharing options...
suds2250 Posted June 6, 2012 Share Posted June 6, 2012 +1 on the spacers. I just put some in, after running double spring rubbers, and the ride is much better. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
