see_obxt Posted April 23, 2006 Share Posted April 23, 2006 Edited to add back spaces: This isn't Subi specific... My son's car had really glazed and pitted headlights. I read on the board about sanding the lights on another thread. I was looking for the various sandpapers when I found something from Permatex at Pep Boys. It's called... Headlight Lens Restoration Kit. The lights on his 98 ZX2 look like new now. You can get this kit for $12.99. You can also just get the various wet sandpaper in the below grits and the Plastex and it'll probably come out the same. No pics right now but the results were crystal clear. The kit comes with Wet Sandpaper sheets:1000, 1500, 2000 and 2500, plastic Restoration Polish, cloth and rubber gloves. I also used a spray bottle of luke warm water and a bucket of luke warm water. I also used Meguiars PlastX as the last polish. The polish the kit came with is good but the PlastX is a bit finer. 1. Soak all sheets of sandpaper you'll be using for 10 min in bucket of water. 2. I began with the 1000. If light is just dull, use 2000 first, Fold sheets in 2 inch square. 3. Sand in horizontal direction only. DO NOT USE A CIRCULAR PATTERN.4. Sand both lamps, rinse in bucket several times. Spray with water to clean off between steps. 5. Continue to sand with the 1500 and repeat until 2500 as the last sandpaper. 6. The lights will be glazed at this point but should look uniform. 7. Clean surface with water and let dry. 8. Using the flannel cloth, place good amount of polish and rub in a CIRCULAR PATTERN. Using firm pressure, polish enitre lamp. 9. Clean with water. If lights are still not clear, repeat polish step. 10. As a last step. I polished again with the Plastx polish. Link to comment Share on other sites More sharing options...
see_obxt Posted April 23, 2006 Author Share Posted April 23, 2006 Well, the text got all compressed... sorry. Link to comment Share on other sites More sharing options...
Brady Posted April 23, 2006 Share Posted April 23, 2006 ^^ Link to comment Share on other sites More sharing options...
OCDetails Posted April 24, 2006 Share Posted April 24, 2006 How about you edit it and put spaces where spaces belong. It isn't helping anybody all jumbled up. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
see_obxt Posted April 24, 2006 Author Share Posted April 24, 2006 The spaces were there, twice! Weird... Link to comment Share on other sites More sharing options...
2Simpletons Posted April 24, 2006 Share Posted April 24, 2006 Thanks for the write-up. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted May 7, 2006 Share Posted May 7, 2006 I was at Lee Valley Tools and found some 15, 5 and 0.5 micron (probably around 30,000 grit) sandpaper. The last two grits rock. While doing some paint repairs today I tried out the 5 and 0.5u paper after sanding with 2000 grit paper. The amount of buffing with compound needed after using the ultra fine paper is much less than without the extra sanding. I'd imagine that the ultra fine paper would decrease the work on headlights too. Link to comment Share on other sites More sharing options...
see_obxt Posted May 7, 2006 Author Share Posted May 7, 2006 I'd imagine so. I had thought of using some diamond powder I used for faceting ranging from 10,000 to 100,000 but the two polishes I used were enough. Cleaning the scratches is just like polishing facets, the more grades used the better the the final result. Link to comment Share on other sites More sharing options...
