lilbrudder Posted October 24, 2010 Share Posted October 24, 2010 I am using OS and have copied Mickeyd's stage 2 in rom raider and made some of my own adjustments. When I save it in RR, it does not save it as a .HEX format which makes it unreadable to ECUflash. Any one know how to change the format, I have Peazip but can't remember how I did it last time. Thanks. Link to comment Share on other sites More sharing options...
lilbrudder Posted October 24, 2010 Author Share Posted October 24, 2010 Also does ayone know what CEL codes I will have to disable for Stage 2? thanks. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 24, 2010 Share Posted October 24, 2010 In RR you can save a file as .hex or .bin. I always save as .hex. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
keithk831 Posted October 24, 2010 Share Posted October 24, 2010 Yeah, you have to type in .hex in the filename when you save it. It won't automatically assign it an extension. I save mine as Keith Rev 1.hex (type that into the Save As box), for example Link to comment Share on other sites More sharing options...
Infamous1 Posted October 24, 2010 Share Posted October 24, 2010 Yeah, you have to type in .hex in the filename when you save it. It won't automatically assign it an extension. I save mine as Keith Rev 1.hex (type that into the Save As box), for example Under the edit>Romraider settings tab you can add the file association. If this isn't done you have to do it manually as you suggested. Link to comment Share on other sites More sharing options...
lilbrudder Posted October 26, 2010 Author Share Posted October 26, 2010 You guys nailed it, adding .hex at the end worked, I figured it was something too easy. and I figured the codes to disable were P0420 and all the ones with EGT in it. Thanks for the tech support....mods, this one can be closed. Link to comment Share on other sites More sharing options...
