Grounding Issue...
Okay. The 22E is in & plugged up but when I plug up the battery, the driver's side radiator fan comes on immediately as does the check engine light while the key is in the off position. So from this mishap, I am assuming that one of the grounds isn't connected correctly or at all. Does anyone have a picture out layout where the grounds that bolt to the engine are? I have yet been able to start it due to this issue.
