rs6er Posted May 23, 2011 Share Posted May 23, 2011 As you know, the RBS grill only has 2 attachment tabs (at the top) instead of 4. As a result, mine has a small gap at the bottom and at very high speed makes a loud howl. What have others done to attach the bottom part of the grill for more stability? Link to comment Share on other sites More sharing options...
rs6er Posted May 25, 2011 Author Share Posted May 25, 2011 Sorry. Wrong forum. Link to comment Share on other sites More sharing options...
Kaptan Posted May 25, 2011 Share Posted May 25, 2011 You should put a piece of cardboard or some type of shim inside the bottom of the grill. This is the fix that RBS suggested. Link to comment Share on other sites More sharing options...
rs6er Posted May 25, 2011 Author Share Posted May 25, 2011 I had used a slice of one of those bubble Fedex packs, but I recently found that it had fallen behind the grill. Wish they had put 4 tabs on the grill. Link to comment Share on other sites More sharing options...
titoedge Posted July 18, 2011 Share Posted July 18, 2011 You should put a piece of cardboard or some type of shim inside the bottom of the grill. This is the fix that RBS suggested. use corrugated cardboard folded on itself a few times, pops the bumper up just enough. Link to comment Share on other sites More sharing options...
rs6er Posted July 18, 2011 Author Share Posted July 18, 2011 I used to have a piece of a FEDEX bubble mailer. Guess I'll put it back. Link to comment Share on other sites More sharing options...
