kvn5 Posted June 25, 2012 Share Posted June 25, 2012 HI I am about to pick up a set of Whiteline KCA399 rear camber bushings. Has anyone installed these without using a press? I was thinking either a C-clamp ball joint tool or DIY bolt and socket puller. Anybody have any ideas or comments or tips they can share? thanks a bunch. Link to comment Share on other sites More sharing options...
Justin case Posted June 26, 2012 Share Posted June 26, 2012 If you have something the correct size the ball joint press might work. Either way make sure you set your alignment how you want it and make sure they're tight. I didnt get mine tight enough and they moved. I went to re-do my alignment at work yesterday and couldn't move the damn things at all. Link to comment Share on other sites More sharing options...
Heedz Posted June 26, 2012 Share Posted June 26, 2012 Not gonna happen. They are IN there. Link to comment Share on other sites More sharing options...
m sprank Posted June 26, 2012 Share Posted June 26, 2012 Press. Link to comment Share on other sites More sharing options...
kvn5 Posted June 27, 2012 Author Share Posted June 27, 2012 i was trying to avoid taking them somewhere but if a press is the easiest solution then i guess i better check some local shops. can the WL bushings be installed with just a C-clamp or vise? Link to comment Share on other sites More sharing options...
m sprank Posted June 27, 2012 Share Posted June 27, 2012 Install can be done without a press. removal of OEM, not so much. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted June 30, 2012 Share Posted June 30, 2012 I actually just did mine the other day without a press. And they dont get much more stuck in than what mine was. You can see from my pics my car is all rust. I think the only reason mine came out with my bench vice is because it was painted neon hot pink for the added clamping force. http://legacygt.com/forums/showthread.php/rear-camber-adjustment-whiteline-kca399-install-188434.html Link to comment Share on other sites More sharing options...
OutbackXT05 Posted June 30, 2012 Share Posted June 30, 2012 I honestly thought I was going to have to go to a shop and get them pressed out but I said screw it and just went for it. I was surprised I got them out with the vice and hammer. Didnt heat it up or anything. Link to comment Share on other sites More sharing options...
lingling1337 Posted June 30, 2012 Share Posted June 30, 2012 Hey XT I looked at your guide, what size socket did you use to press the OEM bushing out? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted June 30, 2012 Share Posted June 30, 2012 I used a 15/16 1/2 drive socket to push it out. And a 1 1/4 inch 1/2 drive to recieve it. The 1.25 socket was a bit too small and got stuck in it. It was the biggest socket i had so 1 size bigger if you have 1 laying around. Link to comment Share on other sites More sharing options...
Impulse Posted April 27, 2014 Share Posted April 27, 2014 for future reference, I was able to get these installed with the arm still on the car and without a hydraulic press. I only used the advance auto ball joint/u joint puller master kit. This thread helped me figure it out! http://legacygt.com/forums/showthread.php/kca399-install-car-and-w-o-hydraulic-press-224531.html?p=4804417#post4804417 Link to comment Share on other sites More sharing options...
