GP2001 Posted September 27, 2009 Share Posted September 27, 2009 Hey guys, having trouble locating an improved metal TOB to replace the crappy oem one. Where can I get one of these from? I have looked around but cant find one... Link to comment Share on other sites More sharing options...
schwinn Posted September 28, 2009 Share Posted September 28, 2009 I didn't know there was an improved TOB for our cars - a bearing is a bearing? There is the Tranquil TSK kit, which improves the metal (it's a metal sleeve) on the snout of the transmission... is that what you were looking for? Link to comment Share on other sites More sharing options...
alohajeff Posted October 8, 2009 Share Posted October 8, 2009 If I remember right there was an "adapter" that allowed the use of a Toyota throw out bearing. I replaced my OEM TOB with another OEM TOB because I didn't have time to figure out which bearing could be made to work. A Google search will lead you all over the place but in the end if you are in a hurry I'd run the OEM. Lots of people purchased Tranquil kits and then came to find out the parts didn't fit. That's probably been sorted out by now but 9 months ago they didn't know WTF fit our cars. http://www.smart-service.com/images/store/pdmsnout.jpg The Tranquil sleeve allows the use of a common BCA bearing. The part numbers are shown in the image above on the sticker that mentions the car has been retrofitted with a different TOB. Aloha Link to comment Share on other sites More sharing options...
jah64 Posted October 10, 2009 Share Posted October 10, 2009 do you mean this one? http://www.subaruwrxparts.com/shop/pc/viewPrd.asp?idproduct=2255&idcategory=0#details 5mt repair kit I've read it also stops the chirping of the wrx flywheel/act clutch setup. -instead of using a spring Link to comment Share on other sites More sharing options...
