Cool Legacy Posted May 12, 2011 Share Posted May 12, 2011 It's quite simple to disable the AWD system by installing the fuse as stated in the manual, which would essentially turn the Subaru into a front wheel drive. Wouldn't this give the car much better gas mileage? Could any damage result from disabling the AWD? Just curious... Link to comment Share on other sites More sharing options...
dtmenace Posted May 12, 2011 Share Posted May 12, 2011 this has been covered previously ... please use the sites search feature & don't post the same thread in multiple forums. Link to comment Share on other sites More sharing options...
c-lo Posted May 12, 2011 Share Posted May 12, 2011 are you really just curious or regretting you got AWD? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Cool Legacy Posted May 12, 2011 Author Share Posted May 12, 2011 Seriously curious! Love the AWD but if possible to turn it off in the summer months for improved gas mileage (4.55 gallon where I live) it would be nice. I'm sure it's not that easy though. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 12, 2011 Share Posted May 12, 2011 No fuel economy gains. If the gas mileage bothers you, you should have bought a more efficient car. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 12, 2011 Share Posted May 12, 2011 It's quite simple to disable the AWD system by installing the fuse as stated in the manual, which would essentially turn the Subaru into a front wheel drive. Wouldn't this give the car much better gas mileage? Could any damage result from disabling the AWD? Just curious... That wouldn't be a very "Cool Legacy" if you did that Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 12, 2011 Share Posted May 12, 2011 Seriously curious! Love the AWD but if possible to turn it off in the summer months for improved gas mileage (4.55 gallon where I live) it would be nice. I'm sure it's not that easy though. This will not save you money in fuel, you will get better mileage by NOT stomping on the gas at the stop light and making sure you have a clean air filter. Why would you detract from the abilities of the vehicle in this manner? Just practice better driving habits Link to comment Share on other sites More sharing options...
fishbone Posted May 12, 2011 Share Posted May 12, 2011 There is no easy or straight-forward way of making the car 2wd Link to comment Share on other sites More sharing options...
underground000 Posted May 12, 2011 Share Posted May 12, 2011 OMG my friend drives 85 miles in his 07 FJ and uses 2.3 gallons of gas going uphill! he drafts trucks and goes 55mph, yup the fuel needle barley moves:lol: crazy. Yea the FJ is loaded w/ crap and has bigger "off road" tires. It takes me a quarter tank going the same way when I fly by people at 75 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted May 12, 2011 Share Posted May 12, 2011 You can DEFINITELY make a 5eat RWD or FWD. Frank_ster has done the modification to even do RWD/4WD with a switch. If you want to do strictly RWD or FWD, you can remove the opposing drive shaft (there is a shaft going from center diff to front diff, or there's the obvious rear diff, and while you're there remove differential and axles) as well. You might need to weld the center diff, or you might get away with wiring the Transfer clutch solenoid to be on constantly with Ign power. Then disable P0700 code, etc. I could figure it out by looking a little, or otherwise Frank_ster could just tell you because he has given it some thought. FWD would be easier because you would not need to remove the transmission. Just the tail housing, where the center diff lives. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted May 12, 2011 Share Posted May 12, 2011 so # 1 as i said before the fuse to disable awd is only related to the 4 eat the 4 eat ( 4 speed automatic )is a mechanical front wheel drive trans mission with a add on with a clutch to the rear wheels . when the car is at cruse or in neutral park or engine off its a front wheel drive car. on a 4 eat you can easily remove the drive shaft and rear axles / differential. to become front wheel drive car. the 5 eat ( 5 speed automatic ) has a center differential with a locking clutch. ( 4eat only has a "transfer clutch " ) the fuse does not work with the 5 eat again fuel economy will not gain in either case i have a 2.5I and a 2.5gt the 2.5i manual is amazing on gas ! city and even better on gas. comparable to a accord the 2.5gt is decent highway mpg but terrible city mpg partially because the weight of the car but i believe its more to do with the exhaust restriction of the small turbo. of witch i'm working with climber d to see how well a exhaust bypass works. i have seen 4 eat converted to rear wheel drive / 4 wheel drive . witch helps with the play factor and i am doing the same with my 5 eat. witch i have a thread about. somewhere .. i think Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 If you remove the axles, the wheels will fall off. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted May 13, 2011 Share Posted May 13, 2011 If you remove the axles, the wheels will fall off. I've never even given it a thought until now... The hub doesn't hold on the wheel? Lug nuts? Thought the half shafts just transfered rotational power from the differentials to the hubs... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 I've never even given it a thought until now... The hub doesn't hold on the wheel? Lug nuts? Thought the half shafts just transfered rotational power from the differentials to the hubs... The axle nut is the only thing preventing the hub from pulling out of the bearing. No axle nut, and the hub can, and will, vibrate itself out. And there goes the wheel! The stub sandwiches the bearing between the carrier (that bolts to the knuckle) and the hub. It was worse on the older cars that didn't have the bolt in housings. Those wheels would fall off after a few hundred yards, and the bearings would be ruined after a few dozen feet. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
milesej05 Posted May 13, 2011 Share Posted May 13, 2011 Take either your front wheels or rear wheels off...that will literally make it TWO WHEEL drive...unless you wanted only one wheel drive then take off three wheels. Simple math... Kind of like the any number to the 0 power =1 Link to comment Share on other sites More sharing options...
frank_ster Posted May 13, 2011 Share Posted May 13, 2011 If you remove the axles, the wheels will fall off. i am aware .. but you just put a bolt in it with the right size washers we use front wheel drive hubs and knuckles for trailers and such all the time. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 Technically, no Subaru outside the STi is more than 3 wheel drive, and if you are unlucky enough to not have a rear LSD, then the best you can do is 2wd anyway. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 i am aware .. but you just put a bolt in it with the right size washers we use front wheel drive hubs and knuckles for trailers and such all the time. I know that YOU know. But how many normal people would have put those two things together? I typically disassemble the CV and just use the outer cup and axle nut to hold everything together. That's what I did when I converted my old car to RWD for a while. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
frank_ster Posted May 13, 2011 Share Posted May 13, 2011 Take either your front wheels or rear wheels off...that will literally make it TWO WHEEL drive...unless you wanted only one wheel drive then take off three wheels. Simple math... Kind of like the any number to the 0 power =1 are you serious ? if you remove random wheels on a typical awd you will damage the center differential Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
MatsuDano Posted May 13, 2011 Share Posted May 13, 2011 Drive with parking brake on. Link to comment Share on other sites More sharing options...
milesej05 Posted May 13, 2011 Share Posted May 13, 2011 DanoH has the idea. Its a joke dude! If you remove the front 2 or back 2 wheels and don't put any other wheels on you will have two WHEEL drive. Link to comment Share on other sites More sharing options...
MatsuDano Posted May 13, 2011 Share Posted May 13, 2011 Disconnecting your rear brake lines also helps with fuel economy, you won't be burning up all that speed with silly things like stopping. Link to comment Share on other sites More sharing options...
milesej05 Posted May 13, 2011 Share Posted May 13, 2011 ^^^ haha...i think a mod should just go ahead and close this thread. Link to comment Share on other sites More sharing options...
MatsuDano Posted May 14, 2011 Share Posted May 14, 2011 Come on now, its all I'm good fun. OP, sorry to say but just don't worry about it. You wont gain much if anything by going 2wd. Sent from my Droid using Tapatalk Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted May 15, 2011 Share Posted May 15, 2011 I think we're all aware of this lacking in practicality. But it is still fun (for some) to work out the hypothetical. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
