ktm200 Posted March 10, 2012 Share Posted March 10, 2012 Poking around on Cobb's website I took a look at the map notes for the 05-06 GT's and stage 1 93oct power is rated at 273hp and 300ft/lbs. When I look at the 07-09 map notes power is rated at a 4% hp increase and 9% torque. Since the 07-09 cars are rated at 243hp/241torque stock this increase works out to be 253hp and 263ft/lbs for stage 1 93oct. This is a 20hp and 37ft/lbs difference between the 2 groups of GT's!? Why is there such a massive difference? I tried emailing cobb and got a vague response. I thought the GT had the same motor from 05-09. Cobb mentioned the ecu is slightly different for the newer cars but the gains for the 09 seem very small. Is the 07-09 more restrictive somewhere? Thanks Link to comment Share on other sites More sharing options...
Code Posted March 10, 2012 Share Posted March 10, 2012 Ots maps are going to make different power on every car, regardless of year. Those numbers that you quoted aren't worth crap. Also, search vf46 "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ktm200 Posted March 10, 2012 Author Share Posted March 10, 2012 Ots maps are going to make different power on every car, regardless of year. Those numbers that you quoted aren't worth crap. Also, search vf46 VF46 stock on the 07-09 cars. Thought they were considered slightly more ecficient. Wasn't sure how that effects the much different power numbers. I'm speaking out of ignorance though. I don't know of the intricacies between the two sets of cars. Anyone have an idea of the numbers the 07-09 stage 1 can actually put out. Eventually I'll go stage 2 but the real reason for this thread is to find out what the restriction is behind the powers numbes for the 07-09 compared to the 05-06 so I can plan out my next upgrade. Link to comment Share on other sites More sharing options...
Code Posted March 10, 2012 Share Posted March 10, 2012 Stage 1 will be 215 ish @ the wheels. Stg2 will be 240ish "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ericem Posted March 10, 2012 Share Posted March 10, 2012 does a 07lgt+ have more whp stock because it has a catless uppipe to begin with. Link to comment Share on other sites More sharing options...
ktm200 Posted March 10, 2012 Author Share Posted March 10, 2012 Stage 1 will be 215 ish @ the wheels. Stg2 will be 240ish Thanks. AP should be in next week. Hopefully it's a comfortable bump. Link to comment Share on other sites More sharing options...
