rcruz17 Posted June 30, 2014 Share Posted June 30, 2014 so today i installed new shifter bushings on my 05 lgt and my shifter still wobbles!! I do notice I slight firmness while shifter like now it just goes straight it but the shifter still has a lot of noticeable play. its a stock shifter didnt have lock ring pliers to install SS so its untouched. The play is not coming from the 12mm bolt that attaches to the Shifter that is solid I actually notice it moving more from the bottom could it be that white plastic assembly where my shifter sits in that is worn out? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2014 Share Posted June 30, 2014 Yes. It is 9+ y/o. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rcruz17 Posted June 30, 2014 Author Share Posted June 30, 2014 I tried looking for shifter assembly on subaruoemparts.com could not find it whats it listed under? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2014 Share Posted June 30, 2014 I know there's a nylon bearing on the shifter, is it that ? I seem to recall the outter case of the shifter bolts hard to the tranny. It's been a couple years since I've been there. I seem to recall two bolts. make sure both are tight. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted June 30, 2014 Share Posted June 30, 2014 Adding to Max's list... there is a u-joint in the shifter linkage under the car that can loosen up. When I replaced my shifter, I noticed that some slop was actually where the little roll-pin goes through the u-joint to attach to the transmission selector rod. The roll pin itself was fine, but holes it passes through in the u-joint were wearing oblong and had a bit of play. Replacing the u-joint (dealer part) tightened that up. Try to wiggle the linkage around and observe everything for play. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
rcruz17 Posted June 30, 2014 Author Share Posted June 30, 2014 Its not on the shifter bolt i see it moving inside under lock ring that has to be removed to change shifter Link to comment Share on other sites More sharing options...
rcruz17 Posted July 2, 2014 Author Share Posted July 2, 2014 ok I got under the car and noticed that U-joint its wobbling around the pin that goes thru it doesnt look like fun to change im having a hard time even finding it listed on any websites or even a part number. Link to comment Share on other sites More sharing options...
heiche Posted July 2, 2014 Share Posted July 2, 2014 Dealer part # is 35046AG000 The roll pin holding it to the trans shifter rod is actually two - a smaller one inside of a larger one. You can find something the side of the smaller one and tap it out with a hammer. Then tap out the larger one with a slightly larger drift (mine was pretty tight). The other side is a bolt/nut. I did mine with the trans on the bench. Probably more challenging with everything in place BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
