Blumpkin Posted April 8, 2013 Share Posted April 8, 2013 So here is the story, I was driving around last night and the car started to idle rougher than usual so I hooked up the AP and started looking at some numbers. The AFR hopped up to 20.3 as opposed to the normal 14.7, my boost went from 17.5 at peak down to 8.9 and when I pulled codes I got that I was running too lean, as obvious by the AFR and misfire on all 4 cylinders, anyone got any ideas? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2013 Share Posted April 8, 2013 vacuum leak ? Have you zip tied all the small hoses ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Blumpkin Posted April 8, 2013 Author Share Posted April 8, 2013 yeah don't mind me, it was the vacuum hose off the bov, its all better now, I feel like an idiot though Link to comment Share on other sites More sharing options...
