subarulegay Posted January 3, 2013 Share Posted January 3, 2013 Guys I need your help, we've been getting some -20 celcius weather and when ever I start it for the first 5 seconds of the engine running it is as if there is a loud belt whining noize. The belts were changed this summer with gates belts. Just wondering if there is anything to do to avoid the squealing noise or what could cause it. Link to comment Share on other sites More sharing options...
ripemeat Posted January 3, 2013 Share Posted January 3, 2013 tighten the belt a little Link to comment Share on other sites More sharing options...
mwiener2 Posted January 3, 2013 Share Posted January 3, 2013 It's a common problem. It's not the belts. Never been able to figure out exactly what it is. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
gear_monkey Posted January 3, 2013 Share Posted January 3, 2013 I didn't think it was the belts either because mine did the same thing two days ago and I have just put new belts on myself...if I tighten them anymore I'm afraid they will snap. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2013 Share Posted January 3, 2013 Are you sure it's not the starter hanging up for a couple of seconds ? That's a common problem too. You need to grease the starter shaft that the gear slides on to engage the FW. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robinlsb Posted January 3, 2013 Share Posted January 3, 2013 Not to worry. Mine has always done that, with no problems down the road since new. It sounds terrible, but the engine is still fine. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 3, 2013 Share Posted January 3, 2013 Isn't that the beginning of the TOB failure? When mine went I thought it was a belt squeal at first. Find a vid of the TOB noise to verify its not that. Link to comment Share on other sites More sharing options...
robinlsb Posted January 3, 2013 Share Posted January 3, 2013 Isn't that the beginning of the TOB failure? When mine went I thought it was a belt squeal at first. Find a vid of the TOB noise to verify its not that. Nope:) TOB squeal occurs at any Temp:) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
-Samurai- Posted January 3, 2013 Share Posted January 3, 2013 Mine does this as well. No idea what is is. I had a 2000 Toyota Celica that also did this at very cold temps but never had a problem caused by it. Still a mystery. Sounds really bad but goes away in like 3 seconds. Very odd. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 3, 2013 Share Posted January 3, 2013 Nope:) TOB squeal occurs at any Temp:) Ahh.. So it was just a coincidence that my TOB went when the weather started to cool. Mine sounded the worst when it was cold.. but the cold had nothing to do with it? Interesting. Link to comment Share on other sites More sharing options...
PeterJMC Posted January 3, 2013 Share Posted January 3, 2013 Mebe a freezing idler pulley due to cold temps? Link to comment Share on other sites More sharing options...
robinlsb Posted January 3, 2013 Share Posted January 3, 2013 Ahh.. So it was just a coincidence that my TOB went when the weather started to cool. Mine sounded the worst when it was cold.. but the cold had nothing to do with it? Interesting. Drive until it is warm. Then start it up, listen, put in gear. If it whines TOB. If not, then go right ahead and replace parts for no reason:p "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 4, 2013 Share Posted January 4, 2013 Drive until it is warm. Then start it up, listen, put in gear. If it whines TOB. If not, then go right ahead and replace parts for no reason:p Thanks for the sarcasm.. Good thing I already replaced the TOB 3 months ago.. and good thing I didn't get your advice then. My TOB disintegrated when I touched it. I'm lucky it waited to spill bearings until AFTER the car was on jackstands. Once again, thanks for the help! Link to comment Share on other sites More sharing options...
robinlsb Posted January 4, 2013 Share Posted January 4, 2013 Thanks for the sarcasm.. Good thing I already replaced the TOB 3 months ago.. and good thing I didn't get your advice then. My TOB disintegrated when I touched it. I'm lucky it waited to spill bearings until AFTER the car was on jackstands. Once again, thanks for the help! I presumed you knew how to drive a standard shift. My bad:rolleyes: If you are going through TOBs, like they are water, then the problem is with the operator. If your TOB is toast after three months, then YOU have a problem. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
racso_dor Posted January 4, 2013 Share Posted January 4, 2013 increase the volume of your radio while you turn your car on ...abakadabra you hear no more noise Link to comment Share on other sites More sharing options...
lingling1337 Posted January 4, 2013 Share Posted January 4, 2013 I presumed you knew how to drive a standard shift. My bad:rolleyes: If you are going through TOBs, like they are water, then the problem is with the operator. If your TOB is toast after three months, then YOU have a problem. Legit question here what kind of shifting behaviors do you want to avoid to prevent tob failure? I'm new to stick and had to replace the stock tob at about 90k miles after I had been driving it for about 4k miles and don't want to have to do it again any time soon Link to comment Share on other sites More sharing options...
mwiener2 Posted January 4, 2013 Share Posted January 4, 2013 keep foot off clutch pedal as much as possible My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 4, 2013 Share Posted January 4, 2013 I presumed you knew how to drive a standard shift. My bad:rolleyes: If you are going through TOBs, like they are water, then the problem is with the operator. If your TOB is toast after three months, then YOU have a problem. Wow. My TOB is not toast... I had issues 3 months ago, replaced it, and now its fine. I was talking from past experience... Not talking about a current issue. Sorry I gave you the wrong impression. Link to comment Share on other sites More sharing options...
ScottFW Posted January 5, 2013 Share Posted January 5, 2013 Legit question here what kind of shifting behaviors do you want to avoid to prevent tob failure? I'm new to stick and had to replace the stock tob at about 90k miles after I had been driving it for about 4k miles and don't want to have to do it again any time soon Basically what mweiner said, but these are some specific bad habits: 1. Too many drivers sit through the entire duration of a red light with the trans in gear and the clutch pedal to the floor. That might save you one whole second compared to just leaving it in neutral until the light turns green, but it MURDERS the lifespan of the TOB. If there's one big no-no, this is it. The trans should be in neutral and the only pedal pressed should be the brake, until you are ready to go "right now." And who knows, that extra second it takes to put it in gear might one day keep you from getting T-boned by the dickhead who just ran the red light. 2. Don't hold the car on uphill grades by slipping the clutch. Same deal as #1 but also puts wear on your clutch in addition to the TOB. 3. Don't rest your foot on the clutch pedal. That's what the dead pedal is for. Your foot should only be on the pedal for that one second at a time (give or take) while you are actively shifting gears. If you don't do any of the above, then probably at 90K your TOB just died of natural causes and not from any mechanocidal habits on your part. My TOB died quite suddenly about 1,000 miles after I bought the car. It had 97K on it. Maybe it was just its time, or maybe the PO's driving habits contributed to its demise, I can't say. Subaru has not done us any favors either, since the stock clutch & DMFW setup at least on the 05-06 LGT has a really heavy pressure plate for a stock pseudo-luxury car. I forget where I saw the exact spec so I won't post an erroneous number here, but the stock piece has a higher clamping force than many aftermarket pressure plates that are considered "heavy duty" by their manufacturers. The heavier the pressure plate, the stiffer the clutch pedal (given a constant hydraulic system), the greater the load on your TOB and the shorter the TOB is likely to last. Lighter pressure plate and pedal feel were among the factors in my choosing a Clutchmasters instead of something else when I had to replace mine last month. Link to comment Share on other sites More sharing options...
PeteCool Posted January 9, 2013 Share Posted January 9, 2013 The whine is much louder at -50C! I had that last winter while I was in Alberta. I'm guessing the oil is thicker and it's not where it needs to be yet. FWIW, I did not experience any issues from the whine, car ran great this summer. Just keep engine speed low until the car is warm. Link to comment Share on other sites More sharing options...
Matt166 Posted January 9, 2013 Share Posted January 9, 2013 Mine has been whining a little, it's been well below 0f some nights. Bit originally started with a 2 second belt squeal, now the alternator will whine for 10 seconds or so, it could be on the way out I guess. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 9, 2013 Moderators Share Posted January 9, 2013 I've had a trifecta of noises on start up now that it's cold again--2 of them happened last year as well. One is a slight chirp / whistle right as the key is turned--no effing clue what it is. The other is a slight grind as I let off the key, which I'm pretty sure is the starter saying "lube me up". I need to do that. Both of these noises have been present intermittently during completely cold starts, neither is really causing an issue. The last noise is belt noise from the power steering belt, only happens on the first turn I make for the day and only happens every now and then. I replace the belt not to long ago and just need to tighten it up. If anyone knows what the unknown noise is (chirp noise), let me know "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Daniels Posted January 11, 2013 Share Posted January 11, 2013 Install the tsk3 clutch kit, noise gone. From what I have read on here. Link to comment Share on other sites More sharing options...
outahere Posted December 14, 2013 Share Posted December 14, 2013 Guys I need your help, we've been getting some -20 celcius weather and when ever I start it for the first 5 seconds of the engine running it is as if there is a loud belt whining noize. The belts were changed this summer with gates belts. Just wondering if there is anything to do to avoid the squealing noise or what could cause it. Could be the TOB Could be the PS belt or AC belt is too loose. Could be a bad AC idler pulley Could be a bad timing belt idler pulley Could be that the starter shaft needs cleaning and lube. Could be a squealing PS pump or alternator or water pump Link to comment Share on other sites More sharing options...
OBPLegacyGT Posted December 16, 2013 Share Posted December 16, 2013 I had the same problem. I recently had the belts replaced so I thought it strange to have the belts squealing at start up. I tightened the alternator belt, but when I attempted to tighten up the other belt, I accidentally broke off the bottom piece on the bracket and had to remove the entire stud. however, no more squeaking... Link to comment Share on other sites More sharing options...
