ible Posted May 20, 2006 Share Posted May 20, 2006 I am planning to upgrade my brakes. I've already done tires but the braking still stinks esp. on a stage 2 car. I'd like to do pads (bobcats, HPS, or endless), lines, fluid and rotors. Should I get slotted or blank rotors? I don't track the car or autocross it. Besides the additional cost, what are the negatives to slotted? Noise, increased wear, dust, etc.? Link to comment Share on other sites More sharing options...
PhilT Posted May 20, 2006 Share Posted May 20, 2006 Unless your stock rotors are worn, I wouldn't bother changing them. You are not going to see any real difference in stopping power, unless you track the car hard. By doing paads, lines and fluid, you will see a huge difference alone. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Edvig Posted May 20, 2006 Share Posted May 20, 2006 Unless your stock rotors are worn, I wouldn't bother changing them. You are not going to see any real difference in stopping power, unless you track the car hard. By doing paads, lines and fluid, you will see a huge difference alone. what he said Link to comment Share on other sites More sharing options...
MDW25gt Posted May 20, 2006 Share Posted May 20, 2006 Just turn the rotors. Pads, lines and fluid. Good to go, er stop! Link to comment Share on other sites More sharing options...
Shea Posted May 20, 2006 Share Posted May 20, 2006 I am really hard on my brakes and get them heated up quickly from slowing and going on the interstate. I have turned my Wrangler's rotors twice and recently replaced them due to me being hard on them. Only has 20k miles. Would it still not help me either? Link to comment Share on other sites More sharing options...
MDW25gt Posted May 20, 2006 Share Posted May 20, 2006 I am really hard on my brakes and get them heated up quickly from slowing and going on the interstate. I have turned my Wrangler's rotors twice and recently replaced them due to me being hard on them. Only has 20k miles. Would it still not help me either? I do not understand the question?? Link to comment Share on other sites More sharing options...
Shea Posted May 20, 2006 Share Posted May 20, 2006 Would changing the rotors help in my problem? It seems the answer to the above poster's question was no, but was wondering if my circumstance may call for these rotors due to my braking. Link to comment Share on other sites More sharing options...
MDW25gt Posted May 20, 2006 Share Posted May 20, 2006 Unless the rotors are below the "spec" thickness or warped I see no need to change them. Link to comment Share on other sites More sharing options...
Shea Posted May 20, 2006 Share Posted May 20, 2006 What I mean is, once it needs replaced, would it be worth the extra money. Link to comment Share on other sites More sharing options...
PhilT Posted May 20, 2006 Share Posted May 20, 2006 What I mean is, once it needs replaced, would it be worth the extra money. I don't know the cost difference between the OEM and the aftermarket rotors, but I wouldn't imagine it's much. I will be going with drilled or slotted when mine need changing, just for the bling factor. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
robinlsb Posted May 20, 2006 Share Posted May 20, 2006 Drilled rotors are from the old days. Slotted do make a difference, but only from a maintenance and rotor life standpoint. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
sgt Posted May 20, 2006 Share Posted May 20, 2006 Dont bother with slotted rotors. If you ever track the car, after one session the slots will be filled up with brake dust. Link to comment Share on other sites More sharing options...
ible Posted May 20, 2006 Author Share Posted May 20, 2006 Okay. So for my needs blanks are best. Is there any advantage of using the DBA blanks over our OEM blanks? Link to comment Share on other sites More sharing options...
blkwag Posted May 20, 2006 Share Posted May 20, 2006 DBA slots are very nice w/ the carbotek bob cat pads, ss.lines and motul fluid. To me it was a lot better! Had that set up on my old 03 Impreza TS wagon. Went from drums to rotors in the back as well. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 21, 2006 Share Posted May 21, 2006 Slotted rotors eat pads faster.. only on full-blown race cars is it really worth it imo. I would eventually like to upgrade to a stock size plain rotor with better cooling vanes for track days. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
