BrianEarlSpilner Posted October 22, 2014 Share Posted October 22, 2014 Just got done with head work and put the engine back in.... 1) ERR HC on the dash-temp gauge to full hot and not able to crank engine 2) Accessport won't turn on via OBDII port 3) buzzing sound behind glovebox when key is turned on (last a few seconds) I've checked and re-made the grounds (1 on each head), and triple checked ground on the starter. Ive reconnected the engine harness ensuring its attached. What else can cause this? I haven't done anything but "unplug" the ECU since teardown Link to comment Share on other sites More sharing options...
cryo Posted October 22, 2014 Share Posted October 22, 2014 This situation is almost always engine grounds or harness not plugged in issues. I know you said you checked them but I have a feeling that is what you will find is causing your issue. Expecially with the ap not booting up. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
