DamienC Posted January 9, 2013 Share Posted January 9, 2013 I was investigating my air con/radio unit today and when i removed the gear stick cover and ash tray, i noticed a small switch on the right. I couldnt see where it led to after much effort! But i've no idea what it does if I switch it off. Anyone else know what it could be? I tried and considered the following: Alarm Bypass, Ignition bypass, Boost controller switch, ABS off swtich, Hidden lights.... Pics to follow soon! Link to comment Share on other sites More sharing options...
ehsnils Posted January 9, 2013 Share Posted January 9, 2013 Trunk opening inhibit switch? To prevent someone to open the trunk from inside the car. Link to comment Share on other sites More sharing options...
Nrw Posted January 9, 2013 Share Posted January 9, 2013 Be careful, that's the passenger seat ejection switch. Link to comment Share on other sites More sharing options...
DamienC Posted January 9, 2013 Author Share Posted January 9, 2013 Be careful, that's the passenger seat ejection switch. Im not gonna lie, didnt sit in either front seat while fiddling with it :-p Do scoobys have a Trunk opening inhibit switch? (or is that a joke?) Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 9, 2013 I Donated Share Posted January 9, 2013 Do scoobys have a Trunk opening inhibit switch? (or is that a joke?) No, but they do have a keylock on the trunk release, which is down by your left foot. My guess is a previous owner of your car put that switch in. Link to comment Share on other sites More sharing options...
GTTuner Posted January 9, 2013 Share Posted January 9, 2013 Picture? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 10, 2013 I Donated Too Share Posted January 10, 2013 sounds like an aftermarket alarm valet switch that no one ever really installs properly... or needs... Link to comment Share on other sites More sharing options...
AkumaMax Posted January 10, 2013 Share Posted January 10, 2013 Picture? Link to comment Share on other sites More sharing options...
DamienC Posted January 14, 2013 Author Share Posted January 14, 2013 Sorry for the delay, had a crazy weekend. Here it is, Its located on the bottom right behind where the ashtray is, under the AC unit. my car is RHD so i'm guessing it was put on that side for a reason.... Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 14, 2013 Share Posted January 14, 2013 See if the wires goes to the place that the green connectors are. The ones you put together to Flash new maps to the ECU. I did that to mine, make it easier to flash maps. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
DamienC Posted January 14, 2013 Author Share Posted January 14, 2013 if they do go there, why the on/off switch? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 14, 2013 I Donated Too Share Posted January 14, 2013 Toggle the ability to write to the ecu but that still looks like a valet switch... Very after market and definitely not stock Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 14, 2013 Share Posted January 14, 2013 So you can flick a switch to flash & then drive after you loaded a new map. Instead of crawling under the dash & pulling the green connectors out from under the carpet in the foot well. To connect & unconnect the green connectors. Green connectors are only together when flashing you ECU. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
DamienC Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks hammer! Mystery..... Solved ;-) Now.... whats the noise from my rear window sill? :-p Don don dooonnnnnnnnnnnnnnnnnn Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted January 17, 2013 Share Posted January 17, 2013 That's brilliant.. and elegant. My tuner would appreciate that switch very much. Link to comment Share on other sites More sharing options...
