blackturboblack Posted October 1, 2011 Share Posted October 1, 2011 Hey folks, here's the story. Did a fair amount of high speed highway cat and mouse with other tuned cars. I'm thinking maybe some of the higher speed manouvers may have cracked one of the welds on the fire wall because when it rained (it's) been raining a lot here) I noticed water coming in on the passenger compartment - right where your hfeet would be. Looked around and could see nothing - I'm thinking one of the shields came loose or something. Noe. Took it to my mech and they blew out all the weep holes and hosed the car - nothing. Took it through car wash - water again. They took apart glove compartment, front wiper tray, etc, hosed it - nothing. So, when the mech sarts to drive it back to me, he sees the water again. He's thinking like I am that a seam cracked and the water gets through when the motion of the car moves the water. Where and why there's water, I don't know. Car will be dissassembled and sealed. However, my question(s) is: should I get one of those frame braces to keep this from happening again? Or sways and endlinks? Will the brace even fit with my FMIC? Also, one of the mechs is telling me my car isn't designed to handle all that power and can't handle like a sports car. He says my stock wheels are garbage and I need better wheels to be safe at high speeds. WTF? Thanks, I know it's a long read. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 1, 2011 Share Posted October 1, 2011 The FRAME CAN TAKE THE TORQUE FINE. Ockham's Razor http://legacygt.com/forums/showthread.php/water-passenger-footwell-18050.html?t=18050&highlight=water+passenger+footwell oh...and find a new mechanic Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 1, 2011 Share Posted October 1, 2011 Your water problem has nothing to do with the amount of torque you make, I promise you that. You would be the first Subaru in history to have that problem. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 1, 2011 Share Posted October 1, 2011 oh...and find a new mechanic This. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted October 1, 2011 Mega Users Share Posted October 1, 2011 You have it all: A street racing/kill story Misinformation Confusion Exasperation In real life land, your car's frame is strong enough to handle dangerous, high speed maneuvers on public roads with other ricers, sorry, tuners. I think you should buy every sway, brace, and bushing available though. You'll also want to invest in at least a set of STI BBS's. Those are rated for high speed maneuvering. In regards to the leaky frame, you should probably drop the engine, trans, axles, all electronics. The interior should be removed as well. I've seen this before on less capable vehicles and it is definitely a real concern. When will these auto manufacturers learn to not use such brittle steel in their frames? Link to comment Share on other sites More sharing options...
ehsnils Posted October 1, 2011 Share Posted October 1, 2011 Before stating that it's a frame crack (or really an Unibody crack) then you should find the leak - and usually when you get water on the floor it's the water drain from the ventilation system that has popped off. Link to comment Share on other sites More sharing options...
iNVAR Posted October 1, 2011 Share Posted October 1, 2011 You guys suck... Can't believe no one quote this for the record. Hey folks, here's the story. Did a fair amount of high speed highway cat and mouse with other tuned cars. I'm thinking maybe some of the higher speed manouvers may have cracked one of the welds on the fire wall because when it rained (it's) been raining a lot here) I noticed water coming in on the passenger compartment - right where your hfeet would be. Looked around and could see nothing - I'm thinking one of the shields came loose or something. Noe. Took it to my mech and they blew out all the weep holes and hosed the car - nothing. Took it through car wash - water again. They took apart glove compartment, front wiper tray, etc, hosed it - nothing. So, when the mech sarts to drive it back to me, he sees the water again. He's thinking like I am that a seam cracked and the water gets through when the motion of the car moves the water. Where and why there's water, I don't know. Car will be dissassembled and sealed. However, my question(s) is: should I get one of those frame braces to keep this from happening again? Or sways and endlinks? Will the brace even fit with my FMIC? Also, one of the mechs is telling me my car isn't designed to handle all that power and can't handle like a sports car. He says my stock wheels are garbage and I need better wheels to be safe at high speeds. WTF? Thanks, I know it's a long read. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted October 1, 2011 Share Posted October 1, 2011 Inspect around windshield and side glass. Doors with no frame around glass are prone to leaks Link to comment Share on other sites More sharing options...
rao Posted October 1, 2011 Share Posted October 1, 2011 Subscribed for eventual oil content. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 1, 2011 Share Posted October 1, 2011 ^Yeah. What about the oil you use? Improper lubrication may cause the seams to pop due to increased vibrations from the engine. Engines that make torque like this frequently cause this to happen. Link to comment Share on other sites More sharing options...
Penguin Posted October 2, 2011 Share Posted October 2, 2011 Hey folks, here's the story. Did a fair amount of high speed highway cat and mouse with other tuned cars. I'm thinking maybe some of the higher speed manouvers may have cracked one of the welds on the fire wall because when it rained (it's) been raining a lot here) I noticed water coming in on the passenger compartment - right where your hfeet would be. Looked around and could see nothing - I'm thinking one of the shields came loose or something. Noe. Took it to my mech and they blew out all the weep holes and hosed the car - nothing. Took it through car wash - water again. They took apart glove compartment, front wiper tray, etc, hosed it - nothing. So, when the mech sarts to drive it back to me, he sees the water again. He's thinking like I am that a seam cracked and the water gets through when the motion of the car moves the water. Where and why there's water, I don't know. Car will be dissassembled and sealed. However, my question(s) is: should I get one of those frame braces to keep this from happening again? Or sways and endlinks? Will the brace even fit with my FMIC? Also, one of the mechs is telling me my car isn't designed to handle all that power and can't handle like a sports car. He says my stock wheels are garbage and I need better wheels to be safe at high speeds. WTF? Thanks, I know it's a long read. I have heard of this happening before, the only sure way to find the leak is to drive the car into standing water no shallower than two to two and a half feet deep. The door seals will hold up to this just fine and you can.then try to isolate where water is entering. Link to comment Share on other sites More sharing options...
laz Posted October 2, 2011 Share Posted October 2, 2011 I have heard of this happening before, the only sure way to find the leak is to drive the car into standing water no shallower than two to two and a half feet deep. The door seals will hold up to this just fine and you can.then try to isolate where water is entering. This is good advice, but if I am not mistaken the instructions per Subaru say that it needs to be salt water. Am I mistaken? X --- Link to comment Share on other sites More sharing options...
tito_b0y Posted October 2, 2011 Share Posted October 2, 2011 This is good advice, but if I am not mistaken the instructions per Subaru say that it needs to be salt water. Am I mistaken? X Salt water for MT, distilled water for AT. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
laz Posted October 2, 2011 Share Posted October 2, 2011 Salt water for MT, distilled water for AT. Good deal, this is what makes this site the best, the good flow of good information and the eagerness that members have to disburse it! :thumbsup: X --- Link to comment Share on other sites More sharing options...
Max Capacity Posted October 2, 2011 Share Posted October 2, 2011 I would blow out the hose for the AC drain on the bottom of the firewall. So all that water can drain out of the vent system. Or were we not supposed to tell this brainchild that simple tip for stopping water in the passenger foot well ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Penguin Posted October 2, 2011 Share Posted October 2, 2011 While that might work, I am pretty sure that my method will be more effective. Also for those concerned about water type according to my mechanic any reasonably soap free water will do. Soapy water is not desirable as the strong base in a soap can damage the aluminum intercooler if the water sloshes onto it. Perhaps the best method I have ever heard of is to use the same method with a mild solution of boric acid instead of water. This is expensive though, and not widely available outside of the factory. No mater which way the OP goes, he should have all the welded seams of the unitbody magnafluxed (magnetic particle tested) to ensure their integrity. Simple visual inspection will not always reveal a bad weld. Link to comment Share on other sites More sharing options...
BDII Posted October 2, 2011 Share Posted October 2, 2011 subscribe Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Subyduby-doo Posted October 2, 2011 Share Posted October 2, 2011 Hey folks, here's the story. Did a fair amount of high speed highway cat and mouse with other tuned cars. I'm thinking maybe some of the higher speed manouvers may have cracked one of the welds on the fire wall because when it rained (it's) been raining a lot here) I noticed water coming in on the passenger compartment - right where your hfeet would be. Looked around and could see nothing - I'm thinking one of the shields came loose or something. Noe. Took it to my mech and they blew out all the weep holes and hosed the car - nothing. Took it through car wash - water again. They took apart glove compartment, front wiper tray, etc, hosed it - nothing. So, when the mech sarts to drive it back to me, he sees the water again. He's thinking like I am that a seam cracked and the water gets through when the motion of the car moves the water. Where and why there's water, I don't know. Car will be dissassembled and sealed. However, my question(s) is: should I get one of those frame braces to keep this from happening again? Or sways and endlinks? Will the brace even fit with my FMIC? Also, one of the mechs is telling me my car isn't designed to handle all that power and can't handle like a sports car. He says my stock wheels are garbage and I need better wheels to be safe at high speeds. WTF? Thanks, I know it's a long read. Not that it will make a difference but the brace you speak of sounds to me like a strut tower bar. The body braces are mounted underneath the car. These will firm up the flexing of the unibody structure a bit. Strut tower bars are basically useless for our cars. ____Spending funds in mass quantities! I keep telling myself it's just a hobby? Link to comment Share on other sites More sharing options...
silver04RS Posted October 2, 2011 Share Posted October 2, 2011 My car doesn't leak... This is how I checked LOL [ame=http://www.youtube.com/watch?v=g9UsIxfoSkc&feature=youtube_gdata_player]Colfax Underbody Wash - YouTube[/ame] Link to comment Share on other sites More sharing options...
frank_ster Posted October 2, 2011 Share Posted October 2, 2011 mine makes a lot of torque and it doesn't leak. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
doccrowley Posted October 2, 2011 Share Posted October 2, 2011 WHAT????? You mean my sways won't fix my passenger's wet feet? Damn! Wasted money again. Time to change mechanics and start driving like an ass hat on the freeways again! Link to comment Share on other sites More sharing options...
ehsnils Posted October 2, 2011 Share Posted October 2, 2011 If there's a leak due to a bad or missing weld then it's probably time to check with the NTSB since the integrity of the crash protection may be compromised. Link to comment Share on other sites More sharing options...
blackturboblack Posted October 3, 2011 Author Share Posted October 3, 2011 Wow! Thanks guys. The level of expertise here just amazes me. Link to comment Share on other sites More sharing options...
slomoe2008 Posted October 3, 2011 Share Posted October 3, 2011 Check sunroof drain lines. They run down the posts and get clogged at exit. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 3, 2011 Share Posted October 3, 2011 Wow! Thanks guys. The level of expertise here just amazes me. I'm sorry, but what did you think the response would be? No matter what, you don't make the most power a Subaru has ever seen. If frame strength would have been an issue, don't you think someone else would have found that out in the 6 years the LegacyGT has been in production? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
