Kalien32 Posted December 12, 2013 Share Posted December 12, 2013 Been looking around, and cant seem to find a definitive answer... Question is: will the Brakes, off my 05 LGT, swap over to my little brothers 97gt? Im about to go Brembo. Want to give him my slotted brakes from my car. I saw that there is a wrx brake swap, but couldnt find anything on a 4th gen brake swap. Thanks. Link to comment Share on other sites More sharing options...
lockmedic Posted December 12, 2013 Share Posted December 12, 2013 Fronts I know will. . . my logic being that I'm running 05 LGT brakes on my 2000 OBW, and I've swapped 2000 OB front brakes to earlier (95-99) outbacks. Rears? no idea. probably so. Subaru likes to get a lot of life out of their parts-making-machinery, it seems. Obviously he'll need 17" wheels to clear the fronts. Link to comment Share on other sites More sharing options...
Kalien32 Posted December 12, 2013 Author Share Posted December 12, 2013 Thanks. Sounds promising. Im trying to track down some 05 gt wheels for him, aswell. So he should be set after i get those. =) Link to comment Share on other sites More sharing options...
r3v_v3ng3 Posted December 12, 2013 Share Posted December 12, 2013 Front and rears will fit, i have the same setup on my 98lgt. You just have to be creative on routing the rear brakelines since the 05 rear calipers is angled different Link to comment Share on other sites More sharing options...
Zues Marine Posted December 12, 2013 Share Posted December 12, 2013 Yup^ Looks like you searched erreywhere but the stickies up top bro, info is in there Link to comment Share on other sites More sharing options...
Kalien32 Posted December 12, 2013 Author Share Posted December 12, 2013 Searched the stickies. Thats where i found the wrx swap. And found one that talked about the rears from an 00+ legacy. But nothing on the fronts. I was assuming that the fronts would work. But i have has some bad luck with assumptions in the past. I asked about the whole setup. I hate posting new threads, so i search for quite a while looking for specific information. still had a question after looking all over. So i decided to ask. Thank you for the help, though. Link to comment Share on other sites More sharing options...
Zues Marine Posted December 12, 2013 Share Posted December 12, 2013 All good, the lgt rotors are wider than the wrxs too so that's a plus Link to comment Share on other sites More sharing options...
Kalien32 Posted December 12, 2013 Author Share Posted December 12, 2013 Yeah. From what ive read, the LGT brakes are better than WRX. Lil bro will love them! Link to comment Share on other sites More sharing options...
lockmedic Posted December 12, 2013 Share Posted December 12, 2013 Yep. Waaay better. WRX (excluding STi) brakes didn't really get interesting until around 08 and even then it was mostly cosmetics. Everyone (including myself, once upon a time) thinks WRX=awesomesaucegofastJDMyo! Meanwhile, LGT's spank 'em in every category. . . Link to comment Share on other sites More sharing options...
Zues Marine Posted December 13, 2013 Share Posted December 13, 2013 Everyone thinks WRX=awesomesaucegofastJDMyo! Meanwhile, LGT's spank 'em in every category. . . And you can usually find them cheaper (used) because of this as well, from people parting out on CL or junkyards Link to comment Share on other sites More sharing options...
Regardie Posted December 17, 2013 Share Posted December 17, 2013 The 05 GT fronts got a little bigger than the 00-04 fronts so he will need 17's. The rears stayed the same diameter but went from solid to vented so any H6 upgrade writeup would be a good place to start. He will need to remove the dust shield in the rears. Link to comment Share on other sites More sharing options...
lockmedic Posted December 17, 2013 Share Posted December 17, 2013 I would say they got a lot bigger (01 H6 rotor in front, 05 LGT rotor in rear): Thicker too: Aside from Brembos or some crazy aftermarket goodness, they're pretty much the Mandingo of OEM Subaru brakes. But yes, 17"s required. Mentioned that in post #2. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 17, 2013 Share Posted December 17, 2013 Hmm, I wonder how they compare to the WRX 4/2 pots. The GTs are probably better, but don't look as cool, lol. Link to comment Share on other sites More sharing options...
lockmedic Posted December 18, 2013 Share Posted December 18, 2013 LGT brakes=Mandingo, 08+ WRX 4/2=John Holmes. The comparison above can be reversed to suit the individual's preference for pornstar penis shade. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted December 18, 2013 Share Posted December 18, 2013 I have 01' H6 in back and the OEM up front. Does anyone know if the H6 brakes from 00'-03' changed any? Even in the VDC or L.L. Bean level trim? Link to comment Share on other sites More sharing options...
Zues Marine Posted December 18, 2013 Share Posted December 18, 2013 LGT brakes=Mandingo, 08+ WRX 4/2=John Holmes. I have no idea what these things are. Link to comment Share on other sites More sharing options...
lockmedic Posted December 18, 2013 Share Posted December 18, 2013 I have 01' H6 in back and the OEM up front. Does anyone know if the H6 brakes from 00'-03' changed any? Even in the VDC or L.L. Bean level trim? Don't think so. H6 fronts are the same size as 2002 4cyl brakes AFAIK. Zeus: riiiiiiiiight Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted December 18, 2013 Share Posted December 18, 2013 Loc, So no upgrade from 99' GT brakes? Link to comment Share on other sites More sharing options...
Regardie Posted December 19, 2013 Share Posted December 19, 2013 H6 only applies to the rear rotors. They are the same size for the entire 3rd gen and bigger than what was on the WRX at the time, hence the H6 upgrade for the Impreza. The rotor is 11 inch solid. The 3rd gen fronts are all over the map. They started out being the same as the 2nd gen Outback / GT size, (smaller than the rears) moving up to the 02 WRX size later (03?) on the GT. That made the fronts 11 inch as well, only vented. The 4th gen upped the size of the fronts to 12 inch, and kept the rears at 11 inch, moving from solid to vented. All sizes are rounded since I am doing this from memory. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
