subiedoutlegacy Posted June 1, 2014 Share Posted June 1, 2014 I'm completely at a loss at the moment with this car. I just recently bought it and not long after it through a code with a super rough idle. Code 14 injector one so as any normal person would do I replaced injector one. To my dismay the code and rough idle still remains. This is what else I've checked and done so far, I hope someone can help -replaced spark plugs -replaced wires -new fuel filter -oil change and oil filter -cleaned MAF sensor -checked compression (perfect compression) -checked timing (good) -checked resistance to injector (good) -checked continuity to injector (good) -checked purge solenoid (good) -checked fuel pressure regulator (good I believe) I'm at a total loss and just want to get it through inspection and running good to enjoy it. Link to comment Share on other sites More sharing options...
mnstrmech Posted June 1, 2014 Share Posted June 1, 2014 Have you checked for a pulse from the ECU at the injector while the car is running? If you have a new injector on cyl 1 but still have that same code/symptom, could be either bad wiring or ECU not firing that injector. Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 2, 2014 Share Posted June 2, 2014 Have you checked all the vacuum lines for leaks? I had to replace every single line on my SS including the turbo inlet elbow. Check the resistance of your primary and secondary coils to be safe. Link to comment Share on other sites More sharing options...
subiedoutlegacy Posted June 11, 2014 Author Share Posted June 11, 2014 Update The car now has new pulley but still a code. I have also done a compression test with great results 160 on #1 & #4 150 on #2 & #3 still need to do a hot test on it though. Also installed a boost gauge yielding 6 pounds of boost solid when driving. On idle the boost gauge jumps so I will soon be getting a smoke test done on the car. In addition I am starting to believe it may be a bad fuel pressure regulator knowing that the car has had periods of time sitting. Also when squeezing the return line on the fuel filter the car stops idling rough and the boost gauge stays steady. Once I can I'll be checking with a fuel pressure gauge also. Link to comment Share on other sites More sharing options...
USLiberty Posted June 11, 2014 Share Posted June 11, 2014 did you check for vacuum leaks? starting fluid sprayed on suspected vacuum leak will momentarily increase the idle. full boost at 6psi sounds low, sounds like the boost controller isnt limiting boost, sounds like the the wastegate spring is the only boost control... possibly a vacuum leak around there. Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 11, 2014 Share Posted June 11, 2014 Yeah, stock boost on a 22T should be 8.7 psi. You could build a boost leak detector like mine for cheap and it helped me find all of my boost leaks: http://legacygt.com/forums/showthread.php/diy-boost-leak-tester-ss-199337.html I had to replace every single vacuum line on my SS. A common leak is the turbo inlet elbow. They break just by looking at them. JB quick can fix them sometimes. I had some serious fueling issues with my SS as well. Cleaning the MAF never hurts anything. My MAF went bad and it took me months to pinpoint as the problem. The fuel pump was shot and the fuel filter was clogged, the injectors were toast, and the coil pack was out of spec. Link to comment Share on other sites More sharing options...
subiedoutlegacy Posted June 14, 2014 Author Share Posted June 14, 2014 Update Pt2 -Installed new fuel pressure regulator -Replaced vacuum lines on passenger side -Swapped coil pack with a working one on my other legacy Still car runs with same issues but a bit less aggressive with the shake. There are a few more test I am going to run today which are. -Checking IAC valve -Checking PCV valve -Fuel Pressure Test -Check Resistance on fuel pump -ECU to injector resistance Link to comment Share on other sites More sharing options...
subiedoutlegacy Posted June 14, 2014 Author Share Posted June 14, 2014 Any other test suggested? I am down to check anything. Link to comment Share on other sites More sharing options...
subiedoutlegacy Posted June 15, 2014 Author Share Posted June 15, 2014 Well I am stumped...everything checked out IAC resistance was perfect on plug and connector Fuel pressure stayed at 32 psi PCV valve had vacuum still One strange thing is the MAF resistance it gave weird readings between 1 & 2 was 1.5 mega ohms, between 1&4 it was .65 mega ohms and between 2& 4 it was 1.3 mega ohms. According to the manual it was suppose to be 1 mega ohm on 1,2, & 4. I guess I am off to do a smoke test but who knows. Link to comment Share on other sites More sharing options...
subiedoutlegacy Posted June 15, 2014 Author Share Posted June 15, 2014 It is finally possibly solved! I finally got my hands on a vacuum pressure and leak tester and found an immense amount of leaks.Thank god I haven't been driving the car with it so bad, I am going to be spending the week replacing the lines wish me luck on this finally fixing it! Link to comment Share on other sites More sharing options...
