762x39 Posted June 13, 2015 Share Posted June 13, 2015 The ever so famous cylinder 4 misfire. I am having a debilitating misfire on #4 under boosted acceleration. It does not misfire under normal acceleration or idle. Plugs are new. I swapped injectors 2 and 4 and the misfire did not follow. I tried a brand new coil pack. No luck. Are there any other possible causes of this misfire or am I completely screwed? Link to comment Share on other sites More sharing options...
KRM Posted June 13, 2015 Share Posted June 13, 2015 Any oil loss at all? Take it to a indipendant subaru shop and have a comp/leak down done. Start there before you make any final decision Link to comment Share on other sites More sharing options...
762x39 Posted June 13, 2015 Author Share Posted June 13, 2015 Just normal oil consumption. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 13, 2015 Share Posted June 13, 2015 any oil loss at all? Take it to a indipendant subaru shop and have a comp/leak down done. Start there before you make any final decision x2 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SPooky_leggy Posted June 13, 2015 Share Posted June 13, 2015 Any oil loss at all? Take it to a indipendant subaru shop and have a comp/leak down done. Start there before you make any final decision X1,000 but in all seriousness, best advice right here.My engine had a misfire in #4 cylinder and i thought the same as u, took it to a good Subaru shop and found out the engine was fine, all good on the compression test for me, since then, i changed the spark plugs and also made sure im not using crappy fuel, and for the last 4 months i haven't seen any signs of misfire! Link to comment Share on other sites More sharing options...
starionesir Posted June 13, 2015 Share Posted June 13, 2015 Have a leak down done to check for a valve issue and general engine health. You could have a burnt valve which wouldn't be uncommon. Still a rather large repair but cheaper then a new short block. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 14, 2015 Share Posted June 14, 2015 Make sure the coil wire is connected really well, some one found that was there issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
