swagon2.5 Posted August 7, 2014 Share Posted August 7, 2014 Just wondering of anyone has ever adjusted the front window on an 05 Legacy wagon? When I put the window up it goes up unlevel, it has a new track system and still does it, from the sounds of it, it needs adjustment. Any help is great Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted August 8, 2014 Share Posted August 8, 2014 Take off the door card and remove the plastic seal, if it's still there. You should have access to the window at that point. If you're not comfortable doing the work, a decent body shop would be able to handle this in a flash. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
