Dam itz Lou Posted March 21, 2011 Share Posted March 21, 2011 Right now im thinking of putting Tein h-techs on it but im just wondering what's the next upgrade before I drop money on these ? Would it be worth the extra money ? I'm doing this just for the looks, not for performance or anything like that. If that matters... Link to comment Share on other sites More sharing options...
mk6933 Posted March 21, 2011 Share Posted March 21, 2011 What kind of upgrade are you looking at? Well, are you getting the H-techs new or used? If you are getting new, I would recommend the Epic, which are reproduction of Eibach. Similar drop to the H-techs. Link to comment Share on other sites More sharing options...
Dam itz Lou Posted March 21, 2011 Author Share Posted March 21, 2011 H techs with stock struts. Link to comment Share on other sites More sharing options...
joeblow Posted March 21, 2011 Share Posted March 21, 2011 If you're looking strictly at the aesthetic aspect of them, the difference between the springs is going to be the drop amount. Performance-wise you're comparing springs rates and progressive vs linear spring rates. Progressive rate are going to be softer under normal driving conditions and stiffen up at their limits making them more comfortable as a DD. Linear rate are the same spring rate over every bump and through every turn. Other than that, the differences will come with upgrading struts or going with inserts. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
