WRX TMIC an upgrade for Legacy?
I am just starting to read up on the TMIC upgrade. I understand that an 08+ TMIC will fit in an 05 Legacy GT... but is it larger or do I just need to concentrate on aftermarket or Bulletproofing? Frankly $700+ for a TMIC makes it impossible for me.
I had a perrin tmic before i switched to a WBR fmic on stage 3 mods. i did make a little more power, but with all the engine bay clutter the intercooler piping takes up and scraping i get from the lower intercooler pipes, i think a tmic is the way to go for a dd if top hp isnt a priority.
Isn't their boost lag going from a top mount to front? That's ALOT farther the boost has to travel. I've always like the top mounts on my wrxs
Not if you have a good tune....though keep in mind that the 2.0 in the wrx doesn't have the same torque output the 2.5 does so unless you have a big turbo that requires a front mount in a wrx, there will be a noticeable difference. Though, bigger turbo=more lag anyway...
