gsr94 Posted March 3, 2013 Share Posted March 3, 2013 hey guys, i have a 05 LGT, and i was cleaning the battery, i took of the negative battery terminal connector and in doing so i ripped the actual metal piece apart. where do i get the part and how do i swap it out. many thanks! Link to comment Share on other sites More sharing options...
Nickz31se-r Posted September 18, 2013 Share Posted September 18, 2013 did you ever get a part number? Link to comment Share on other sites More sharing options...
cheeseburger Posted September 2, 2014 Share Posted September 2, 2014 Bumping this as my negative battery clamp completely cracked and will no longer clamp onto the battery terminal. Tracing the clamp back to the wire, it looks like it's crimped and soldered on. Am I going to have to replace the entire cable, or is there enough left that I can snip off the clamp and crimp on a new one? Anyone have part numbers? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2014 Share Posted September 2, 2014 Any auto parts store, Kmart, walmart, etc. will have a new crimp on end, about $3.00. Go get one. When you go to start the car next time, You have now reset the ECU, turn the key to ON for 10 seconds then start the engine. It starts better that way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jdtrager Posted September 2, 2014 Share Posted September 2, 2014 Mine did the same thing, only it was like it was streched. I went ahead and just got a new OEM battery cable assy. It comes with all the wires and whatnot ready to install, took 20 mins. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 2, 2014 Share Posted September 2, 2014 ^^that's the best route. Otherwise you can get some great terminals from Jegs. They have matching boots as well: http://www.jegs.com/i/QuickCar+Racing/635/57-620/10002/-1 http://www.jegs.com/i/QuickCar+Racing/635/57-607/10002/-1 Link to comment Share on other sites More sharing options...
