Center Console swap question
robot8282
Would anyone be able to tell me if the analog climate control is plug and play with the digital JDM double din center console?
http://images.dealer.com/evox/stills_0640/4215/4215_st0640_055.jpg
^^This is essentially what is in my car now, except I have a double din. However, I would really like to install this one below, but i want to know first if everything will just plug right in
http://www.avojdm.com/product_info.php?products_id=200
Manual and automatic climate controls are two different beasts...you could technically do it but you would end up replacing a lot of parts and spending a ton of cash. It would probably be cheaper to sell your car and buy one with the automatic climate if you want it that bad.
https://www.amazon.com/Scosche-SU2025B-2005-Up-Subaru-Outback/dp/B001EBJTK6/ref=sr_1_1?ie=UTF8&qid=1466715527&sr=8-1&keywords=legacy+gt+double+din
Ta da!
Slightly cheaper solution. Unless you're actually going for the auto climate control and not just the double din.
Yea that's the dash that's in my car right now, thank you though. I've understood this is a way more complicated task than I was originally thinking it was going to be
