wagdaddy Posted November 28, 2010 Share Posted November 28, 2010 My 95 legacy is a little slow on take off. I'm thinking a new coil wires and plugs. Plus a stronger fuel pump may help. Thoughts ? Link to comment Share on other sites More sharing options...
SBT Posted November 28, 2010 Share Posted November 28, 2010 Clean: Throttle bodyIdle air SolenoidCoil packs and spark plug wires (of carbon buildup)Replace: Spark plugsAir filterFuel filterPCVPlug wires and/or coil pack (if they fail the check test)Do: Grounding mod (Link)Check Crank Position Sensor (manages dwell and timing)Check knock sensorTry another gasoline grade or distributor - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Zues Marine Posted November 28, 2010 Share Posted November 28, 2010 I like that post. Lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 28, 2010 Share Posted November 28, 2010 WOW! Great post Subitonic. OP basically give yourself a tune-up so that everything is working properly and efficiently. I'm guessing plugs, wires and filter and you will notice a difference. Link to comment Share on other sites More sharing options...
SBT Posted November 28, 2010 Share Posted November 28, 2010 Didn't state whether it was auto or 5MT, presume autobox and 2.2L SOHC engine. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kaz98gt Posted November 29, 2010 Share Posted November 29, 2010 Under that assumption as well...great post subietronic! I was looking for the specs to check life left in my coilpack actually, thanks for the info! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 29, 2010 I Donated Share Posted November 29, 2010 My 95 legacy is a little slow on take off. I'm thinking a new coil wires and plugs. Plus a stronger fuel pump may help. Thoughts ? push the gas down harder I agree with Subietonic 100%. Do that and see what you end up with.  Clean: Throttle bodyIdle air SolenoidCoil packs and spark plug wires (of carbon buildup)Replace: Spark plugsAir filterFuel filterPCVPlug wires and/or coil pack (if they fail the check test)Do: Grounding mod (Link)Check Crank Position Sensor (manages dwell and timing)Check knock sensorTry another gasoline grade or distributor -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
wagdaddy Posted December 14, 2010 Author Share Posted December 14, 2010 Awesome ! Thanks all. Will do and post results Link to comment Share on other sites More sharing options...
SBT Posted December 20, 2010 Share Posted December 20, 2010 Seems like endwrench.com is OTA so hopefully someone captured the coil pack test .pdf before they went OTA. If so, please post it up as I don't have have it on my laptop and getting to my other computer will be difficult (understatement) from here. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kaz98gt Posted December 20, 2010 Share Posted December 20, 2010 Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted December 21, 2010 Share Posted December 21, 2010 Simple things like worn wheel bearings can also cause a slow takeoff. A lurker's .2 cents. Link to comment Share on other sites More sharing options...
carnumber19 Posted December 21, 2010 Share Posted December 21, 2010 If it is the auto a failing torque converter could soak up a good bit of HP as well Link to comment Share on other sites More sharing options...
