sleeper8406 Posted May 16, 2010 Share Posted May 16, 2010 I know lots of people have done it....they say it is easy. I just haven't seen any instructions anywhere how to do it...I did search but I didn't find anything. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2010 Share Posted May 18, 2010 It's pretty easy. You just need a floor jack and a few tools. I did mine back in 04' with a STI mount. Made a huge difference when shifting. It takes a lot of slop out of the drive train. Just be careful you install it centered, some people were hitting the exhaust pipe with there mount. I didn't see that to be a problem. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Windy Road Posted May 18, 2010 Share Posted May 18, 2010 Its fairly easy, I recommend dropping the whole crossmember when you install it. It made it so much easier for me to take the stocker out and put the new on it. Also its a good time to install the Group N crossmember bushings. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted May 26, 2010 Share Posted May 26, 2010 Literally just finished doing this 3 hrs ago. Not difficult at all, I didn't use any instructions or anything. Once you get the car in the air, it's pretty self explanatory. As recommended above, taking off the entire crossmember will be your best bet most likely. At first I just loosened the crossmember to take the stock mount out, but to put the GroupN in, I ended up removing the whole thing anyways. Link to comment Share on other sites More sharing options...
Code Posted May 26, 2010 Share Posted May 26, 2010 Such a great upgrade for the $ "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
sleeper8406 Posted May 26, 2010 Author Share Posted May 26, 2010 What about the cross member mounts? Should I do those too? Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted May 26, 2010 Share Posted May 26, 2010 I installed the crossmember bushings, tranny mount, and kartboy rear bushing on mine, already had a Kartboy STS and front bushings. I can't tell you the difference between having the crossmember bushings and not having them because I installed them both at the same time, but with everything I've got on my car my shift feel has improved a lot. I'd recommend doing it all, you'll be happy you did. Link to comment Share on other sites More sharing options...
Code Posted May 26, 2010 Share Posted May 26, 2010 You have to take the crossmember out anyways. The bushings are like $30. For me it was a no-brainer. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
mustangendsley Posted December 15, 2010 Share Posted December 15, 2010 do you have to have a jack to hold the trany in place after you take the cross member out? Link to comment Share on other sites More sharing options...
Underdog Posted December 15, 2010 Share Posted December 15, 2010 Yes. The Crimson Dynamo Link to comment Share on other sites More sharing options...
