WinTech Posted February 29, 2012 Share Posted February 29, 2012 I have a 2005 LGT. I removed the air silencer a while ago and you could hear a wooshing/sucking sound. It was not loud but you could hear it. Last weekend I started getting a VERY loud similar sound. I can hear it during accelleration above 3000rpm in all gears. There is no noticable loss in power, no check engine light and the car seems to run fine. I cannot hear it if I rev the engine in neutral. Does anybody know what the most likely source of the sound would be? How do I go about tracking it down if I can only hear it while driving around? Link to comment Share on other sites More sharing options...
Strizzy Posted February 29, 2012 Share Posted February 29, 2012 Put the silencer back on. My bad luck build Link to comment Share on other sites More sharing options...
scoobyscoodle Posted February 29, 2012 Share Posted February 29, 2012 Judging by your symptoms, I would say you have a turbo in your car. ^+1 to above. Removing the silencer can cause some weird harmonics due to oscillations in the air pressure in the stock air box. I'd put it back on. Link to comment Share on other sites More sharing options...
charlie_sheen Posted February 29, 2012 Share Posted February 29, 2012 Roll your window up Link to comment Share on other sites More sharing options...
Max Capacity Posted February 29, 2012 Share Posted February 29, 2012 I've had the silencer removed on my 05 since Aug of 2004. I think it sounds awesome... OP You need to watch for signs of the turbo going. Unless a vacuum hose feel off somewhere, when you begin to hear a different sound, it could be the turbo going south. Mine had the P0011 and P0021 codes, then the turbo began to whine, about a 1000 miles late the turbo began to whistle. I stop driving it and replaced the vf40 with a vf52 and had the banjo filter removed. You may want to make sure the filter is removed now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted February 29, 2012 Share Posted February 29, 2012 I've had the silencer removed on my 05 since Aug of 2004. I think it sounds awesome... OP You need to watch for signs of the turbo going. Unless a vacuum hose feel off somewhere, when you begin to hear a different sound, it could be the turbo going south. Mine had the P0011 and P0021 codes, then the turbo began to whine, about a 1000 miles late the turbo began to whistle. I stop driving it and replaced the vf40 with a vf52 and had the banjo filter removed. You may want to make sure the filter is removed now. Yes, anything that changes without you making any changes, means you should try to track down the cause. Similar to the advice i give to folks about gauges. They are relative. If your temp always reads 300 and all of a sudden it reads 315, you may have a problem. The delta is more important than the value displayed. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 29, 2012 Share Posted February 29, 2012 I have a 2005 LGT. I removed the air silencer a while ago and you could hear a wooshing/sucking sound. It was not loud but you could hear it. Last weekend I started getting a VERY loud similar sound. I can hear it during accelleration above 3000rpm in all gears. There is no noticable loss in power, no check engine light and the car seems to run fine. I cannot hear it if I rev the engine in neutral. Does anybody know what the most likely source of the sound would be? How do I go about tracking it down if I can only hear it while driving around? How do you NOT know you have a turbo on your car and this "problem" is your TURBO in action:mad: Sorry as a 2.5i owner I so long for you "problem":rolleyes: Link to comment Share on other sites More sharing options...
jfg22557 Posted February 29, 2012 Share Posted February 29, 2012 I cannot hear it if I rev the engine in neutral. ^ boost/load based. turbo related for sure id say. IMO, put the silencer back on. EDIT: and +1 to ditching the banjo filter if you havnt already... oh, and change your oil for good measure;) Link to comment Share on other sites More sharing options...
jfg22557 Posted February 29, 2012 Share Posted February 29, 2012 the delta is more important than the value displayed. +1 Link to comment Share on other sites More sharing options...
Max Capacity Posted February 29, 2012 Share Posted February 29, 2012 ^ boost/load based. turbo related for sure id say. IMO, put the silencer back on. EDIT: and +1 to ditching the banjo filter if you havnt already... oh, and change your oil for good measure;) May be get a can of engine flush from Subaru on run it through before the oil change. The stuff is like $20.00. I normally just use Gunk motor flush for 5 minutes once or twice a year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jfg22557 Posted February 29, 2012 Share Posted February 29, 2012 ^ definitely a good idea. Auto-rx and amsoil make a flush as well Link to comment Share on other sites More sharing options...
WinTech Posted February 29, 2012 Author Share Posted February 29, 2012 I know the car has a turbo. The silencer has been off over a year. This sound is new and considerably louder than it was when I first took off the silencer. The banjo bolt filter has been removed. The turbo was replaced not long before I purchased the car and other than a bad starter the car has been very reliable. I am going to put the silencer back on to eliminate that from the equation. Again, no check engine light and no loss of power. The car performs as it always has. I changed the oil two weeks ago. Link to comment Share on other sites More sharing options...
eldrego Posted February 29, 2012 Share Posted February 29, 2012 Curious but why remove the banjo bolt filter? Does it clog? Link to comment Share on other sites More sharing options...
Nrw Posted February 29, 2012 Share Posted February 29, 2012 Curious but why remove the banjo bolt filter? Does it clog? It can. Search. Link to comment Share on other sites More sharing options...
Spoonwacker Posted February 29, 2012 Share Posted February 29, 2012 Did you recently install a new air filter? I just switched to the AVO panel filter, and there's much more wooshing and sucking up front. That's what she said. sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
Max Capacity Posted February 29, 2012 Share Posted February 29, 2012 I know the car has a turbo. The silencer has been off over a year. This sound is new and considerably louder than it was when I first took off the silencer. The banjo bolt filter has been removed. The turbo was replaced not long before I purchased the car and other than a bad starter the car has been very reliable. I am going to put the silencer back on to eliminate that from the equation. Again, no check engine light and no loss of power. The car performs as it always has. I changed the oil two weeks ago. There we go...more info. Tighten the bolts at the turbo to TMIC. Be careful, the threads are aluminum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted February 29, 2012 Share Posted February 29, 2012 Curious but why remove the banjo bolt filter? Does it clog? 07+ do not have the banjo filters in question. Link to comment Share on other sites More sharing options...
eldrego Posted February 29, 2012 Share Posted February 29, 2012 07+ do not have the banjo filters in question. Oh thanks dude, wasted my time looking that up, I literally just read that on the "Turbo failure wiki" sticky. Link to comment Share on other sites More sharing options...
Mill Posted February 29, 2012 Share Posted February 29, 2012 Mine made the whooshing noise with my K&N. Drove me nuts on my DD so I traded for a stock intake. Now I'm stage 2 and its back. lol. Guess the FMIC just makes things louder all around. This is with the silencer on, too. Just replaced the filter and it did get a bit louder. Its hard to hear over my exhaust though. Link to comment Share on other sites More sharing options...
bmx045 Posted February 29, 2012 Share Posted February 29, 2012 Mine made the whooshing noise with my K&N. Drove me nuts on my DD so I traded for a stock intake. Now I'm stage 2 and its back. lol. Guess the FMIC just makes things louder all around. This is with the silencer on, too. Just replaced the filter and it did get a bit louder. Its hard to hear over my exhaust though. no. it's the fact that the downpipe allows the turbo to flow more out thus taking more in. i still have this stock intake with my process west and 20g and it wooshes like hell and sounds more like an apache helicopter than rushing air due to the compressor blade design Link to comment Share on other sites More sharing options...
WinTech Posted March 5, 2012 Author Share Posted March 5, 2012 The problem turned out to be the connection from the intercooler to the throttlebody, it had come off at the TB. Found a leaking coolant hose near the turbo also so I was able to take care of that at the same time. I also put the silencer back on while I was at. I suspect the connection that came loose may have been at least partially loose for awhile because the car seems to run better than ever now. I was having stuttering issues during acceleration that were intermittent. That issue seems to be mostly gone as it accelerates much smoother now. Link to comment Share on other sites More sharing options...
mzk4lyfe101 Posted March 5, 2012 Share Posted March 5, 2012 best. thread. ever. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 5, 2012 Share Posted March 5, 2012 The problem turned out to be the connection from the intercooler to the throttlebody, it had come off at the TB. Found a leaking coolant hose near the turbo also so I was able to take care of that at the same time. I also put the silencer back on while I was at. I suspect the connection that came loose may have been at least partially loose for awhile because the car seems to run better than ever now. I was having stuttering issues during acceleration that were intermittent. That issue seems to be mostly gone as it accelerates much smoother now. There we go...more info. Tighten the bolts at the turbo to TMIC. Be careful, the threads are aluminum. Glad you found it, that was going to be my next guess. I took the easy one first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lardo420 Posted March 5, 2012 Share Posted March 5, 2012 best. thread. ever. apparently you havent found the proud to be NA thread yet Link to comment Share on other sites More sharing options...
Dntk Posted March 5, 2012 Share Posted March 5, 2012 Do the N/A guys have one of those "pride" parades too? Link to comment Share on other sites More sharing options...
