youknowit Posted October 12, 2011 Share Posted October 12, 2011 This has been happening for a while now, If i go over a bump mainly when im turning I will a noise coming from the driver side front end of my car. Yesterday after i parked the car, I kicked the driver side tire and heard a clanging noise, kicked the passenger tire heard nothing. What might be the cause of this problem? Link to comment Share on other sites More sharing options...
Theride Posted October 12, 2011 Share Posted October 12, 2011 some will say it could be your Endlink Link to comment Share on other sites More sharing options...
Max Capacity Posted October 12, 2011 Share Posted October 12, 2011 Go back and kick that right side tire....I didn't hear it. Most likely end links if the clunking noise is when it hits a crack in the driveway or parking lot. These cars are known for that. Subaru's in general. if it is, IMO do not use OEM style replacements. Use after market solid end links. They use real nut's and bolts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
youknowit Posted October 12, 2011 Author Share Posted October 12, 2011 how hard would those be to install? Link to comment Share on other sites More sharing options...
Theride Posted October 13, 2011 Share Posted October 13, 2011 how hard would those be to install? 5 mins per side. I use rallitek for both fronts and rears Link to comment Share on other sites More sharing options...
AZP Installs Posted October 13, 2011 Share Posted October 13, 2011 They are 5 minutes if the bolts aren't rusted. Otherwise get a good saw or cutting tool. But yes Subarus are known for endlink clunks. Rallitek, Whiteline, Kartboy, and probably a ton more companies have them. Solid endlinks are the way to go since after time the bearing or ball joints wear out and then have to be replaced again. Also make sure to torque them with weight on them. -Jake http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
