poly LCA bushings, long term road tests
SSpeed
Like everyone's stock LCA bushings, mine are torn to shreds... Under braking though my car is rock solid, and the steering input is still very responsive...
Still, I look under at them and think those big tears can't be good for overall suspension responsiveness and stability... Searching around this forum I found this Subaru bulletin:
2005~06my legacy Front lower control arm bushings
Dealers have reported, and in some cases replaced, the Front Lower Control Arms for cracked bushings. Generally, replacement is not necessary. Even with cracks up to 15mm across the outside surface, and all the way through the bushing from one side to the other, the bushing performance is still 20 times the strength of specification.
This type of bushing works with compressed rubber and when the control arm travels through its full stroke it stretches a small portion of the bushing and will exhibit a crack or split. This does not affect the performance of the bushing and will not continue to spread to the rest of the bushing. It does not cause body vibrations, noises, or braking issues. A Service Bulletin will be released outlining the above information. See image to the right.
The portion I question is "when the control arm travels through its full stroke it stretches a small portion of the bushing and will exhibit a crack or split" if that is indeed true, then poly bushings will get stressed under the full stroke of the control arm and perhaps fail more catastrophically eventually...
That's not saying I buy that, but for those who have replaced LCA bushings with poly ones, how long have they lasted and have you seen any problems?
I inspect mine regularly when I'm doing brake swaps or changing wheels. They are holding up just fine. I run the SuperPro set. This article describes how they work and clears up some misconceptions:
http://autospeed.com/cms/title_Custom-Bushes/A_2833/article.html
It's funny that Subaru says: "It does not cause body vibrations, noises, or braking issues." because in our experience, worn LCAs do cause all of those! When I swapped mine all of those went away, everything else constant.
While we're on the subject:
- What's a good lube to use for LCA bushings (can you use somethign like Moble Synthetic grease?) that doesn't hurt the urethane? How often should you do this and what should you take apart to lube it (the inner metal insert/sleeve? (I think there's one))?
- I have whitelines and really like them. My whole set up is quite a bit stiffer than stock, so didn't notice much noise/vib issues on install.
Thanks.
Whiteline doesn't have any 0deg bushings right? I've been looking and can't find any, the standard says 0.5deg. I had ordered up the AVOs, but I guess they're on back order. I'm replacing the struts next week and I know I'm going to notice a lot more wobble from my torn LCA bushing once the other stuff is firmed up.
Less deflection. That means that the suspension works as it is supposed to. Energy is absorbed by the strut, rather than by deflecting bushings. This all provides better control of wheel motion, which provides more predictable and stable handling.
As for a firmer ride, that is inherent of stiffer bushings and such.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
  • 1 year later...
The caster doesnt move the wheel in or out. It rotates it froward or back. We have installed plenty of them on stok soccer mom legacies without any long term issues except amiles ontheir faces.
We usually bundle the inner bushings and the rear of the front lca bushings together.
-mike
http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
Hi Mike. Are those soccer mom Legacies on stock suspensions? I have the AVO offset ones and thinking replacing them with the 08 sti/spec B bushings. After almost two years, I don't think I'll get used to the extra NHV or I'm just getting old:redface:
Yes, hence why i said they were soccer moms. :) just stock legacies who had bad lca bushings. We put in the whitelines and they love em.
-mike
Perhaps there is something else causing he roughness?
-mike
well that's what i'm trying to avoid, any wheel movement, front back or in out. I want it to look like they way it is stock. Any other bushings available to avoid this but are better then OEM (stock)?
The front/back change is almost inpercievable in terms of visal appearance. The Whiteline kit is adjustable so it can be set to stock caster.
We sell the Whiteline KCA334 for $130.
-mike
The caster needs to be adjusted while the alignment is being done. The bushing has these little inserts/sleeves that can be turned by inserting a punch thing into the holes in the sleeve and rotating the sleeve. All the shop has to do is lossen the bolt, and rotate the sleeve and watch the caster change, and retighten once it's where you want it to be.
And as mike said, the visual difference is very, very, very minor. You have to be looking for it to notice the very slight difference in wheel position in the well.
Thank you for your reply...now what's confusing me is that, why would there be ANY difference if caster is set to 0?
At 0 additional caster, there's no difference from stock. But this allows you to *add* an additional 0.5 degrees on top of stock, which brought my total caster to 6.5 degrees I believe. That's what I opted for. I really suggest you add the extra caster if you buy this kit. Seems like a waste to me for you to have it set to stock.
