Mel2058 Posted December 28, 2010 Share Posted December 28, 2010 So I have had my Legacy for only a week and the Turbo went out on it. It is a 2005 with only 68,000 miles. What is better a OEM or aftermarket replacement? Link to comment Share on other sites More sharing options...
black318i Posted December 28, 2010 Share Posted December 28, 2010 Aftermarket is probably better, but is going to require a tune. If you are looking for more power I'd take this opportunity to upgrade otherwise I'd look for a vf46 and just use the pill from your vf40. They go for about $400 or less shipped. Your vf40 is worth some money to someone as a core for an aftermarket hybrid build. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted December 28, 2010 Share Posted December 28, 2010 So I have had my Legacy for only a week and the Turbo went out on it. It is a 2005 with only 68,000 miles. What is better a OEM or aftermarket replacement? Gosh, better is so circumstantial. What are your goals with the car? Do you want to stay stock? Do you have a lot or a little money to spend? Cheap option: remove banjo bolt filters, change out for VF40/46 turbo for $400 with 20k miles on it oem option remove banjo bolt filters, toss in new turbo (over $1000!!!) rebuild option get a rebuilt turbo from BnR. they will rebuilt. mod option buy a downpipe $200, BnR 16g turbo (bigger wheel similar to an sti vf39 turbo power wise in a vf40 stock housing) $700ish after core fee and an infamous1 tune $175? How much money you got to spend? $500? $1000? $1500? Are you the sort who even cares about HP? Many would rather have HID lights, wheels and a body kit (thats fine too, but if you are into modding appearance, dont waste money on go-fast bits). Are you the sort who just enjoys the forum and doesnt what to mod? We need way more info OP Link to comment Share on other sites More sharing options...
Mel2058 Posted December 28, 2010 Author Share Posted December 28, 2010 I enjoy having the turbo for the car because i like having the ability to have some good power when I need it. I would like to not have to buy a new turbo and not spend over $1000 but if i get a rebuilt one, there probably isn't a warranty if it blows again. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted December 29, 2010 Share Posted December 29, 2010 http://legacygt.com/forums/showthread.php/fs-co-vf-46-turbo-and-stock-mufflers-152339.html?t=152339 There is your turbo. You are welcome. Should last another 4-5 years easy. Link to comment Share on other sites More sharing options...
porterdog Posted December 29, 2010 Share Posted December 29, 2010 Did you get the cam position Check Engine light, too? Link to comment Share on other sites More sharing options...
Mel2058 Posted December 29, 2010 Author Share Posted December 29, 2010 Im not the best with cars. What do you mean cam position? The check engine light did came on. Link to comment Share on other sites More sharing options...
jfg22557 Posted December 29, 2010 Share Posted December 29, 2010 ^forgot the code, but common with a blown turbo. happened to me way back too. make sure those banjo filters are outt Link to comment Share on other sites More sharing options...
