joeleodee Posted November 24, 2013 Share Posted November 24, 2013 Well, my ACT HD clutch can no longer hold the power level I'm running especially in these frigid temperatures. Here is my setup. http://legacygt.com/forums/showthread.php/edmundus-turbo-lives-avo-450-tune-175414.html This car for the most part is daily driven and as you can see, 400wtq+ in the cold just slips the clutch loose now even in third. I need some suggestions as to its replacement. I don't mind the tighter engagement of the ACT I'm currently running since I'm used to it. However, I need something that will hold 500+ crank tq that won't be a bear to live with daily. Am I only dreaming? Here's some initial possibilities that I'm considering. -ACT 4 or 6 puck sprung clutch kit -Clutchmasters FX400 4 or 6 puck clutch kit (thinking the 300-350 might not have the holding strength necessary in the long run.) -SPEC STG3+ Clutch kit (though mucho $$$$) Is there any other clutches available for the '05 LGT 5MT that I should be considering? I don't necessarily like my options especially since those 4 and 6 puck style clutches don't have the longevity that I'd like, but I understand I've got to pay to play. Any help is appreciated. Link to comment Share on other sites More sharing options...
doobaruGT Posted November 25, 2013 Share Posted November 25, 2013 I'm not incredibly knowledgeable on the options out there, but I love my competition clutch. It's only their "stage 2", but I got it for the same reason (power threshold) but I'm not planning to go as far as you. GL! Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 25, 2013 Share Posted November 25, 2013 I have great luck with my Spec clutches. checkout their website. A Spec 2+ or 3 should be fine. Contact Mike at http://www.AZPinstalls.com he got me my Spec 2. I had a 2+ for 85,000 mile and was happy with it. My Spec 2 is like stock, just grab's 10X better. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
