slushboxgt Posted December 11, 2009 Share Posted December 11, 2009 Hi, Any way to set the traction control default to off? I would like to be able to still use it if needed (if possible), but I would prefer if it didn't reset each time I start the car. Thanks, Paul Link to comment Share on other sites More sharing options...
shutterbc Posted December 11, 2009 Share Posted December 11, 2009 On an '05-06 GT, the question is "what traction control?" What model are you referring to? I think someone else may have responded to your other post with a potential answer: removing the ABS fuse. I don't think there's a dedicated fuse for VDC... keep in mind I don't own a vehicle with that feature though. Link to comment Share on other sites More sharing options...
E-Tank Posted December 11, 2009 Share Posted December 11, 2009 Is the "traction control" that you are referring to the symmetrical all wheel drive? You can't turn dat off. durp. Link to comment Share on other sites More sharing options...
subie_dude05 Posted December 11, 2009 Share Posted December 11, 2009 there is a fuse that you can pull for when the car is being towed or you are running on the spare tire... just curious why are you trying to disable it on the car? Link to comment Share on other sites More sharing options...
slushboxgt Posted December 11, 2009 Author Share Posted December 11, 2009 I have an '08 LGT 5eat. The car has electronic traction control that works in conjunction with the ABS. There is a disable switch on the dash, but it resets to the on position every time you start the car. I didn't understand that the fuse for the ABS was the same as the one for the traction control. Even though it's the holiday season, don't want the full warning light Christmas tree effect on the dash whenever the car is running... No other options? Posted at the same time Subie dude. I far prefer driving without traction control, I like to steer with the gas pedal some under certain conditions. Traction control works with the ABS to apply the brakes to one or more wheels to prevent sliding the car. I only find it useful under certain limited conditions, prefer to have the default at off. Thanks, Paul Link to comment Share on other sites More sharing options...
subie_dude05 Posted December 11, 2009 Share Posted December 11, 2009 ^^^ ooooooo okay. i dont have them there fancy options in my 05' Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 12, 2009 Share Posted December 12, 2009 anyone for installing a ABS OFF switch? Might add that to the switch list. More fun... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
grimlin Posted January 30, 2010 Share Posted January 30, 2010 subscribed for answer. Link to comment Share on other sites More sharing options...
